Problem interfaceing PIC18F2550 and KS0108 LCD
hkBattousai
Turkey
I've been trying to interface 18F2550 and a 128x64 pixel graphic LCD for weeks. I tried several libraries found on the web, but none of them made the LCD print a single pixel on the screen. I'm really stuck at the moment, and I need guidance and new ideas.
The best library I found so far is the one I found in a forum. You can access the thread from here. For simplicity, I'm going to add source source code of the library below.
I also checked the signal levels at both PIC and LCD pinouts by an oscilloscope, there are meaningful pulses, the system PIC is working for sure.
The major parts I used are listed below:
  1. IDE: MATLAB 8.40 Academic
  2. Compiler: Microchip C18 3.34 Academic
  3. LCD: WG12864B, with KS0108 Controller (Detailed datasheet, Electrical specifications)
  4. PIC: PIC18F2550, with 20MHz crystal(Page, Datasheet)
These are photos of my LCD:
**broken link removed**, **broken link removed**
And these are photos of my circuit:
glcd.h
#include <p18f2550.h>
#define GLCD_Data   PORTB
#define b_GLCD_GCS1 LATCbits.LATC7
#define b_GLCD_GCS2 LATCbits.LATC6
#define b_GLCD_RS   LATCbits.LATC0
#define b_GLCD_RW   LATCbits.LATC1
#define b_GLCD_E    LATAbits.LATA5
#define b_GLCD_On   LATCbits.LATC2
#define b_GLCD_BL   LATAbits.LATA4	// Not used in my project
#define TRIS_Data    TRISB
#define b_TRIS_GCS1  TRISCbits.TRISC7 //GCS1
#define b_TRIS_GCS2  TRISCbits.TRISC6 //GCS2
#define b_TRIS_RS    TRISCbits.TRISC0 //RS
#define b_TRIS_RW    TRISCbits.TRISC1 //RW
#define b_TRIS_E     TRISAbits.TRISA5 //E
#define b_TRIS_On    TRISCbits.TRISC2 //RST
#define b_TRIS_BL    TRISAbits.TRISA4 //backlight
void Delay(void);
unsigned char GLCD_Read(void);
void Wait_Not_Busy(void);
void GLCD_Write_Cmd(unsigned char data);
void GLCD_Write_Data (unsigned char data);
void ClearScreen(void);
void Init_GLCD(void);
void PutChar(unsigned char data);
unsigned char GLCD_Read_Data(void);
void SetPos(unsigned char x,unsigned char y);
void WritePosition(void);
void plot(unsigned char x,unsigned char y);
void hline(unsigned char x,unsigned char y1,unsigned char y2);
void vline(unsigned char x1,unsigned char x2,unsigned char y);
void box(unsigned char x1,unsigned char y1,unsigned char x2,unsigned char y2);
void PutMessage(static char rom *Message);
void PutLogo(static char rom *logo);
glcd.c (a little long, but please bear with me)
#include "glcd.h"
const rom unsigned char Font[96][7];
unsigned char i,XPos,YPos,W;
void plot(unsigned char x,unsigned char y){
unsigned char d;
	if(x>63){
		b_GLCD_GCS1=0;
		b_GLCD_GCS2=1;
		x-=64;
	else
		b_GLCD_GCS1=1;
		b_GLCD_GCS2=0;
	GLCD_Write_Cmd(0x40+x);			//write column address
	GLCD_Write_Cmd(0xb8+(y>>3));	//write row address
	d=GLCD_Read_Data();				//dummy read
	d=GLCD_Read_Data();
	GLCD_Write_Cmd(0x40+x);			//write column address again
	d=d&(0xff-(1<<(y&7)));
	GLCD_Write_Data(d);
void hline(unsigned char x,unsigned char y1,unsigned char y2){
	for(i=y1;i<y2;i++)
		plot(x,i);
void vline(unsigned char x1,unsigned char x2,unsigned char y){
	for(i=x1;i<x2;i++)
		plot(i,y);
	unsigned char x2,unsigned char y2){
	vline(x1,x2,y1);
	vline(x1,x2,y2);
	hline(x1,y1,y2);
	hline(x2,y1,y2);
void Delay(void){
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
	_asm	NOP	_endasm
unsigned char GLCD_Read(void){
	b_GLCD_E=1;Delay();
	Delay();
	W=GLCD_Data;Delay();
	b_GLCD_E=0;Delay();
	return W;
void Wait_Not_Busy(void){
	TRIS_Data=0xff;
	b_GLCD_RS=0;
	b_GLCD_RW=1;
	if (b_GLCD_GCS1==1 && b_GLCD_GCS2==1){
		b_GLCD_GCS1=0;
		while (GLCD_Read()&0x80);
		b_GLCD_GCS1=1;
		b_GLCD_GCS2=0;
		b_GLCD_GCS2=1;
	else{
	TRIS_Data=0x00;
void GLCD_Write_Cmd(unsigned char data){
	Wait_Not_Busy();Delay();
	GLCD_Data = data;Delay();
	b_GLCD_RS=0;Delay();
	b_GLCD_RW=0;Delay();
	b_GLCD_E=1;Delay();
	Delay();
	b_GLCD_E=0;Delay();
void GLCD_Write_Data (unsigned char data){
	b_GLCD_RS=1;Delay();
	b_GLCD_E=1;Delay();
	Delay();Delay();
	b_GLCD_E=0;Delay();
void MoveRight(void){
	if(++XPos==64){
		WritePosition();
	if(XPos==128){
		XPos=0;
		YPos+=8;
		YPos=YPos&0x3f;
		WritePosition();
void WritePosition(void){
	if(XPos>63){
		b_GLCD_GCS1=0;
		b_GLCD_GCS2=1;
	else{
		b_GLCD_GCS1=1;
		b_GLCD_GCS2=0;
	GLCD_Write_Cmd(0x40+(XPos&0x3f));	//column=0
	GLCD_Write_Cmd(0xb8+((YPos&0x3f)>>3));	//row=0
unsigned char GLCD_Read_Data(void){
	Wait_Not_Busy();
	TRIS_Data=0xff;
	b_GLCD_RS=1;
	b_GLCD_RW=1;
	b_GLCD_E=1;
	Delay();
	W=GLCD_Data;
	b_GLCD_E=0;
	TRIS_Data=0x00;
	return W;
void ClearScreen(void){
unsigned char i,j;
	b_GLCD_GCS1=1;Delay();
	b_GLCD_GCS2=1;Delay();
	for(i=0;i<8;i++)
		GLCD_Write_Cmd(0x40);Delay();	//y=0
		GLCD_Write_Cmd(0xb8+i);Delay();	//x=0
		for(j=0;j<0x40;j++)
			GLCD_Write_Data(0xff);Delay();
	SetPos(0,0);Delay();
void Init_GLCD(void){
unsigned char i;
    b_TRIS_GCS1=0;Delay();
    b_TRIS_GCS2=0;Delay();
    b_TRIS_RS=0;Delay();
    b_TRIS_RW=0;Delay();
    b_TRIS_E=0;Delay();
    b_TRIS_On=0;Delay();
    b_TRIS_BL=0;Delay();
    b_GLCD_On=1;Delay();
    b_GLCD_BL=1;Delay();
	GLCD_Write_Cmd(0x3f);Delay();	//display on
	GLCD_Write_Cmd(0xc0);Delay();	//z=0
	ClearScreen();Delay();
void PutChar(unsigned char data){
unsigned char i,d;
	if(data<32){
		switch(data){
			case 13:
				XPos=0;
			case 10:
				XPos=0;
				YPos+=8;
				YPos=YPos&63;
		WritePosition();
	else{
		for(i=0;i<7;i++){
			d=Font[data-32][i];
			if(d!=0x55){
				GLCD_Write_Data(d);
				MoveRight();
		MoveRight();
void PutMessage(static char rom *Message){
	while(*Message!=0)
		if(*Message==0x16){
			*Message++;
			XPos=*Message++;
			YPos=*Message++;
			WritePosition();
		else
			PutChar(*Message++);
void PutLogo(static char rom *logo){
unsigned char w,h,bitcount,Byte;
	w=*logo++;
	h=*logo++;
	bitcount=0;
	do{
		for(i=0;i<w;i++){
			if(bitcount==0){
				bitcount=8;
				Byte=*logo++;
			if(Byte&1) plot(XPos,YPos);
			XPos++;
			Byte/=2;
			bitcount--;
		YPos++;
		XPos-=w;
	}while(--h);
void SetPos(unsigned char x,unsigned char y){
	XPos=x;
	YPos=y;
	WritePosition();
const rom unsigned char Font[96][7]={
	0xFF,0xFF,0xFF,0x55,0x55,0x55,0x55,	//	32
	0xFF,0xA0,0xFF,0x55,0x55,0x55,0x55,	//	33	!
	0xF8,0xFF,0xF8,0x55,0x55,0x55,0x55,	//	34	""
	0xEB,0x80,0xEB,0x80,0xEB,0x55,0x55,	//	35	#
	0xD9,0xB6,0x80,0xB6,0xCD,0x55,0x55,	//	36	$
	0x9C,0xEC,0xF7,0x9B,0x9C,0x55,0x55,	//	37	%
	0xC9,0xB6,0xFF,0xDD,0xAF,0x55,0x55,	//	38	&
	0xFB,0xFC,0xFF,0x55,0x55,0x55,0x55,	//	39	'
	0xE3,0xDD,0xBE,0x55,0x55,0x55,0x55,	//	40	(
	0xBE,0xDD,0xE3,0x55,0x55,0x55,0x55,	//	41	)
	0xEB,0xD5,0xE3,0xD5,0xEB,0x55,0x55,	//	42	*
	0xF7,0xF7,0xC1,0xF7,0xF7,0x55,0x55,	//	43	+
	0x7F,0x9F,0x55,0x55,0x55,0x55,0x55,	//	44	,
	0xF7,0xF7,0xF7,0xF7,0xF7,0x55,0x55,	//	45	-
	0xBF,0x55,0x55,0x55,0x55,0x55,0x55,	//	46	.
	0x9F,0xEF,0xF7,0xFB,0xFC,0x55,0x55,	//	47	/
	0xC1,0xAE,0xB6,0xBA,0xC1,0x55,0x55,	//	48	0
	0xFF,0xBD,0x80,0xBF,0xFF,0x55,0x55,	//	49	1
	0x9D,0xAE,0xB6,0xB6,0xB9,0x55,0x55,	//	50	2
	0xDD,0xBE,0xB6,0xB6,0xC9,0x55,0x55,	//	51	3
	0xE7,0xEB,0xED,0x80,0xEF,0x55,0x55,	//	52	4
	0xD8,0xB6,0xB6,0xB6,0xCE,0x55,0x55,	//	53	5
	0xC3,0xB5,0xB6,0xB6,0xCF,0x55,0x55,	//	54	6
	0xFE,0x8E,0xF6,0xFA,0xFC,0x55,0x55,	//	55	7
	0xC9,0xB6,0xB6,0xB6,0xC9,0x55,0x55,	//	56	8
	0xF9,0xB6,0xB6,0xD6,0xE1,0x55,0x55,	//	57	9
	0xEB,0x55,0x55,0x55,0x55,0x55,0x55,	//	58	:
	0x7F,0x97,0x55,0x55,0x55,0x55,0x55,	//	59	;
	0xF7,0xEB,0xDD,0xBE,0x55,0x55,0x55,	//	60	<
	0xEB,0xEB,0xEB,0xEB,0x55,0x55,0x55,	//	61	=
	0xBE,0xDD,0xEB,0xF7,0x55,0x55,0x55,	//	62	>
	0xFD,0xFE,0xAE,0xF6,0xF9,0x55,0x55,	//	63	?
	0xC1,0xBE,0xA2,0xFF,0xB1,0x55,0x55,	//	64	@
	0x83,0xED,0xEE,0xED,0x83,0x55,0x55,	//	65	A
	0x80,0xB6,0xB6,0xB6,0xC9,0x55,0x55,	//	66	B
	0xC1,0xBE,0xBE,0xBE,0xDD,0x55,0x55,	//	67	C
	0x80,0xBE,0xBE,0xDD,0xE3,0x55,0x55,	//	68	D
	0x80,0xB6,0xB6,0xB6,0xBE,0x55,0x55,	//	69	E
	0x80,0xF6,0xF6,0xF6,0xFE,0x55,0x55,	//	70	F
	0xC1,0xBE,0xB6,0xD6,0x8D,0x55,0x55,	//	71	G
	0x80,0xF7,0xF7,0xF7,0x80,0x55,0x55,	//	72	H
	0xBE,0x80,0xBE,0x55,0x55,0x55,0x55,	//	73	I
	0xDF,0xBF,0xBE,0xC0,0xFE,0x55,0x55,	//	74	J
	0x80,0xF7,0xEB,0xDD,0xBE,0x55,0x55,	//	75	K
	0x80,0xBF,0xBF,0xBF,0x55,0x55,0x55,	//	76	L
	0x80,0xFD,0xF3,0xFD,0x80,0x55,0x55,	//	77	M
	0x80,0xF9,0xF7,0xCF,0x80,0x55,0x55,	//	78	N
	0xC1,0xBE,0xBE,0xBE,0xC1,0x55,0x55,	//	79	O
	0x80,0xF6,0xF6,0xF6,0xF9,0x55,0x55,	//	80	P
	0xC1,0xBE,0xAE,0xDE,0xA1,0x55,0x55,	//	81	Q
	0x80,0xF6,0xE6,0xD6,0xB9,0x55,0x55,	//	82	R
	0xD9,0xB6,0xB6,0xB6,0xCD,0x55,0x55,	//	83	S
	0xFE,0xFE,0x80,0xFE,0xFE,0x55,0x55,	//	84	T
	0xC0,0xBF,0xBF,0xBF,0xC0,0x55,0x55,	//	85	U
	0xF0,0xCF,0xBF,0xCF,0xF0,0x55,0x55,	//	86	V
	0xF0,0xCF,0xBF,0xC7,0xBF,0xCF,0xF0,	//	87	W
	0x9C,0xEB,0xF7,0xEB,0x9C,0x55,0x55,	//	88	X
	0xF8,0xF7,0x8F,0xF7,0xF8,0x55,0x55,	//	89	Y
	0x9E,0xAE,0xB6,0xBA,0xBC,0x55,0x55,	//	90	Z
	0x80,0xBE,0xBE,0x55,0x55,0x55,0x55,	//	91	[
	0xFC,0xFB,0xF7,0xEF,0x9F,0x55,0x55,	//	92
	0xBE,0xBE,0x80,0x55,0x55,0x55,0x55,	//	93	]
	0xF7,0xFB,0xFD,0xFB,0xF7,0x55,0x55,	//	94	^
	0xBF,0xBF,0xBF,0xBF,0xBF,0x55,0x55,	//	95	_
	0xFC,0xFB,0xFF,0x55,0x55,0x55,0x55,	//	96	`
	0xDF,0xAB,0xAB,0x87,0x55,0x55,0x55,	//	97	a
	0x80,0xD7,0xBB,0xBB,0xC7,0x55,0x55,	//	98	b
	0xC7,0xBB,0xBB,0xD7,0x55,0x55,0x55,	//	99	c
	0xC7,0xBB,0xBB,0xD7,0x80,0x55,0x55,	//	100	d
	0xC7,0xAB,0xAB,0xB7,0x55,0x55,0x55,	//	101	e
	0xF7,0x81,0xF6,0xFD,0x55,0x55,0x55,	//	102	f
	0x67,0x5B,0x5B,0xA7,0x55,0x55,0x55,	//	103	g
	0x80,0xF7,0xFB,0xFB,0x87,0x55,0x55,	//	104	h
	0xC2,0xBF,0x55,0x55,0x55,0x55,0x55,	//	105	i
	0x7F,0x7B,0x82,0x55,0x55,0x55,0x55,	//	106	j
	0x80,0xEF,0xD7,0xBB,0x55,0x55,0x55,	//	107	k
	0xFE,0x80,0xFF,0x55,0x55,0x55,0x55,	//	108	l
	0x83,0xF7,0xFB,0x87,0xFB,0x87,0x55,	//	109	m
	0x83,0xF7,0xFB,0xFB,0x87,0x55,0x55,	//	110	n
	0xC7,0xBB,0xBB,0xC7,0x55,0x55,0x55,	//	111	o
	0x03,0xE7,0xDB,0xDB,0xE7,0x55,0x55,	//	112	p
	0xE7,0xDB,0xDB,0xE7,0x03,0x55,0x55,	//	113	q
	0x83,0xF7,0xFB,0xFB,0xF7,0x55,0x55,	//	114	r
	0xB7,0xAB,0xAB,0xDB,0x55,0x55,0x55,	//	115	s
	0xFB,0xC1,0xBB,0x55,0x55,0x55,0x55,	//	116	t
	0xC3,0xBF,0xBF,0xDF,0x83,0x55,0x55,	//	117	u
	0xE3,0xDF,0xBF,0xDF,0xE3,0x55,0x55,	//	118	v
	0xC3,0xBF,0xCF,0xBF,0xC3,0x55,0x55,	//	119	w
	0xBB,0xD7,0xEF,0xD7,0xBB,0x55,0x55,	//	120	x
	0xE3,0x5F,0x5F,0x83,0x55,0x55,0x55,	//	121	y
	0x9B,0xAB,0xAB,0xB3,0x55,0x55,0x55,	//	122	z
	0xF7,0xC9,0xBE,0x55,0x55,0x55,0x55,	//	123	{
	0xFF,0x80,0xFF,0x55,0x55,0x55,0x55,	//	124	|
	0xBE,0xC9,0xF7,0x55,0x55,0x55,0x55,	//	125	}
	0xFF,0xFF,0x55,0x55,0x55,0x55,0x55,	//	126	~
	0x01,0x7D,0x7D,0x7D,0x01,0x55,0x55,	//	127
main.c
#include "glcd.h"
#pragma config WDT		= OFF
#pragma config MCLRE		= ON
#pragma config DEBUG		= OFF
#pragma config LVP		= OFF
#pragma config PLLDIV		= 5			// need 5 for 20MHz xtal
#pragma config CPUDIV		= OSC1_PLL2	// CPU Clock = 96 MHz/2 = 48 MHz
#pragma config USBDIV		= 2			// 96MHz PLL/2 = 48 MHz for USB clock
#pragma config FOSC		= HSPLL_HS	// High Speed Crystal / Resonator with PLL enabled
void main (void)
	Init_GLCD();
	PutMessage((rom char*)"\x16\x24\x08 Blueroom\x16\x20\x10 Electronics\n Title:\n Author:\n Date:\n Hardware:");
	PutMessage((rom char*)"\x16\x38\x18Graphic demo.");
	PutMessage((rom char*)"\x16\x38\x20Mike Webb.");
	PutMessage((rom char*)"\x16\x38\x28June 20 2007.");
	PutMessage((rom char*)"\x16\x38\x30Unicorn.");
	box(1,1,126,62);
	while (1);
	// Working "Hello World" example
	/*unsigned char i, j;
	TRISB = 0;
	while (1)
		PORTB = 0x00;
		Delay1KTCYx(i);
		PORTB = 0xFF;
		Delay1KTCYx(255-i);
Do you have any suggestions to make this project work? If you need any other details about my system, please feel free to ask.
Any help or guidance will be appreciated greatly.
Added after 4 hours 19 minutes:
Someone told me to add the lines
ADCON1=0x0f;	// all digital
CMCON=7;		// no comparators
before anything else in order to make ADC port bits digital (i.e.; to disable to built in ADC feature).
I did so, but it didn't change anything, the LCD screen is still blank.
Hi there,
I was also struggling to find and implement a library for my GLCD some time ago. THe easiest that i found was 'MikroC' from Mikroelectronica.
I also had left out my 'reset' line on the GLCD too :S.
Hope this helps, They also have a serial library for it.
Cheers:D
    hkBattousai
your code above
the problem is simple
you have no start vector {ie system clock} set to your header
more over the main class header you intend to address this driver with
so add the right directive to add a clock
setting compilers and programmers isnt enough
you need to tell the code what its clocking is also
or the micro will wander around somewhat stupified by a lack of inner incentive
basicaly you must set a main clock define in the main header
or the lcd class will inherite the wrong timing vectors
and not run correctly and at the same 'routine times' as your main class
but at an aspect of the main class routines themselfs
and this is not correct for an lcd driver or any driver
a driver should be called while its own class is run at system clock
run and unloaded ,.. and not within vectors of a main class as it dirived routines clocking.,..
so move the clock defines to the main .h
Added after 9 minutes:
its a usefull feature
as you can use a local routine clock that takes a pin input to clock its internal routines
and then once say a scan of the pins and some sort of code is satisfied
the main clock can be used and pll etc engaged
so this is a good feature
interrupt clocks { exection time frames}
code clock {execution clock}
system clock {compiler set but code adjusted per direcitve}
main clock {external or internal low freq or high frequency pllX2.4 or not &| runtime reset}
I finally made it work!!
The problem was that, the library assumes that CSx bit of my LCD is complemented, but they are actually not complemented. I used two NOT gates to complement CS1 and CS2 bit of PIC output before driving LCD with them.
Now... My next aim is interfacing USB port with PIC...
Wish me luck...
hello i am using a pic18f14k50 usb installed microcontroller . I have download the hex file to the microcontroller but when i connect it to the usb it shows a error message ' One of the USB Device attached to the computer is malfunctioned ' I have tried everything please tell me wat to do now.......
thank you!
^ I haven't started USB develeopment yet. But I will start very soon. I will write a tutorial combining USB and LCD interfaces. Then I can help you.
Hi ,
I tried to use the PIC18f14k50 to generate some waveforn on the RC5 pin. There are 6 push buttons and push each one will generate a specific waveform.
So I use a switch with 6 cases in the endless loop and interrupt routine to service each push button.
my code is quite starightforward and the interrupt doesnot work, so I try to use ICD3 and have problem to porgram and dowload it.
The six push buttons are INT0,INT1,INT2, RB4,RB5,RB6 pins.
I am using the internal OSC.
// *** the header file *****
#include <18F14K50.h>
#device ICD=TRUE
#device adc=8
#FUSES NOWDT //No Watch Dog Timer
#FUSES WDT128 //Watch Dog Timer uses 1:128 Postscale
#FUSES LP //Low power osc < 200 khz
#FUSES FCMEN //Fail-safe clock monitor enabled
#FUSES NOBROWNOUT //No brownout reset
#FUSES BORV19
#FUSES NOPUT //No Power Up Timer
#FUSES NOCPD //No EE protection
#FUSES STVREN //Stack full/underflow will cause reset
#FUSES NODEBUG //No Debug mode for ICD
#FUSES NOXINST //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NOWRT //Program memory not write protected
#FUSES NOWRTD //Data EEPROM not write protected
#FUSES NOWRTC //configuration not registers write protected
#FUSES IESO //Internal External Switch Over mode enabled
#FUSES NOEBTR //Memory not protected from table reads
#FUSES NOEBTRB //Boot block not protected from table reads
#FUSES MCLR //Master Clear pin enabled
#FUSES NOPROTECT //Code not protected from reading
#FUSES NOCPB //No Boot Block code protection
#FUSES NOWRTB //Boot block not write protected
#FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOHFOFST
#FUSES WRT0
#FUSES WRT1
#FUSES USBDIV2
#FUSES PCLKEN
#FUSES BBSIZ2K //2K words Boot Block size
#FUSES PLLEN
#FUSES CPUDIV4 //System Clock by 4
#use delay (clock=20m)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
//***** the main C program ****
#include "C:pICC.h"
unsigned char portb_state0=0;
unsigned char portb_state1=0;
unsigned char portb_state2=0;
unsigned int16 count;
unsigned int16 count_buffer;
unsigned int16 count1=0;// debugging
unsigned int16 count2=0;// debugging
unsigned int16 temp_buffer=0;
unsigned int16 port1_high=0;
unsigned int16 port1_high_buffer=0;
unsigned int16 port2_high=0;
unsigned int16 port2_high_buffer=0;
unsigned int16 port1_low=0;
unsigned int16 port1_low_buffer=0;
unsigned int16 port2_low=0;
unsigned int16 port2_low_buffer=0;
unsigned char switch_value=5;
unsigned int1 input_port1;
unsigned int1 input_port2;
unsigned int1 test3_flag=0;
unsigned int1 test4_flag=0;
unsigned int1 test5_flag=0;
unsigned int1 test6_flag=0;
unsigned int1 cmd0[16]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1};
unsigned int1 cmd1[16]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,0};
void wait_a_second (unsigned char sec)
unsigned int i,j;
for (i=0;i<=sec;i++)
for (j=0;j<4;j++) delay_ms(250);
#int_EXT
void EXT_isr(void)
//GIEL=0;// disable interrupt
disable_interrupts(INT_EXT);
if ((switch_value==1))
if (count<1000)
input_port1=1;
port1_high_buffer=port1_high;
port1_low_buffer =port1_low;
count_buffer=count;
ext_int_edge(0,L_TO_H);
else
input_port1=0;
else
switch_value=1;
ext_int_edge(0,H_TO_L);
//GIEL=1; // enable interrupt
clear_interrupt(INT_EXT);
enable_interrupts(INT_EXT);
#int_EXT1
void EXT1_isr(void)
if ((switch_value==2))
if (count<1000)
input_port2=1;
port2_high_buffer=port2_high;
port2_low_buffer =port2_low;
count_buffer=count;
ext_int_edge(1,L_TO_H);
else
input_port2=0;
port2_low_buffer=0;
else
switch_value=2;
ext_int_edge(1,H_TO_L);
clear_interrupt(INT_EXT1);
enable_interrupts(INT_EXT1);
#int_EXT2
void EXT2_isr(void)
disable_interrupts(INT_EXT2);
switch_value=3;
clear_interrupt(INT_EXT2);
enable_interrupts(INT_EXT2);
#int_RB
void RB_isr(void)
disable_interrupts(INT_RB);
portb_state0=input_b();
delay_us(100);
portb_state1=input_b();
delay_us (100);
portb_state2=input_b();
if ((portb_state0&&0x10)&&(portb_state1&&0x10)&&(portb_state2&&0x10))
switch_value=4;
else
if ((portb_state0&&0x20)&&(portb_state1&&0x20)&&(portb_state2&&0x20))
switch_value=5;
else
if ((portb_state0&&0x40)&&(portb_state1&&0x40)&&(portb_state2&&0x40))
switch_value=6;
clear_interrupt(INT_RB);
enable_interrupts(INT_RB);
void main()
unsigned char i;
setup_adc_ports(NO_ANALOGS|VSS_VDD);
setup_adc(ADC_OFF|ADC_TAD_MUL_0);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED,0,1);
setup_timer_3(T3_DISABLED|T3_DIV_BY_1);
set_tris_b(0x70);
set_tris_c(0x07);
//setup_comparator(NC_NC_NC_NC);// This device COMP currently not supported by the PICWizard
setup_oscillator(OSC_8MHZ|OSC_INTRC);
ext_int_edge(2,L_TO_H);
// TODO: USER CODE!!
enable_interrupts(GLOBAL);
while (true){
//TODO Auto-generated main function
if (test3_flag||test4_flag||test5_flag||test6_flag) switch_value=0;
switch (switch_value){
case 0: // reset condition
// if (input(PIN_A3)==0) reset_cpu();
output_low(PIN_C5);
break;
case 1: // port1
input_port1=0;
output_low(PIN_C5);
delay_ms(60);// change of input
output_high(PIN_C5);
delay_us(100);
output_low(PIN_C5);
delay_us(20);
while ((count<1000)&&(!input_port1)) // it takes 5 sec
temp_buffer=4.725*count;
port1_high= 4975 -temp_buffer;
port1_low = 25 +temp_buffer;
delay_us(port1_high);
output_low(PIN_C5);
delay_us(port1_low);
count++;
while((input_port1==1)&&(switch_value==1)&&(count<1000))
count1++;// debugging use
port1_high=port1_high_buffer;
port1_low=port1_low_buffer;
output_low(PIN_C5);
count++;
break;
} // for the switch case1
case 2: // port2
output_low(PIN_C5);
delay_us(100);
output_low(PIN_C5);
delay_us(20);
while ((count<1000)&&(!input_port2)) // it takes 5 sec
port2_low= 4975 -temp_buffer;
port2_high = 25 +temp_buffer;
delay_us(port2_high);
output_low(PIN_C5);
delay_us(port2_low);
count++;
while((input_port2==1)&&(switch_value==2)&&(count<1000))
count2++;// debugging use
port2_high=port2_high_buffer;
port2_low =port2_low_buffer;
output_low(PIN_C5);
count++;
break;
case 3: // port 3
test3_flag=0;
delay_us(100);
output_low(PIN_C5);
delay_us(20);
delay_ms(250);
output_low(PIN_C5);
wait_a_second(2);
test3_flag=1;
break;
case 4: // port 4
test4_flag=0;
output_low(PIN_C5);
delay_us(300);
output_low(PIN_C5);
delay_us(10);
for (i=0;i<16;i++)
if (cmd0==0)
delay_us(2);
output_low(PIN_C5);
delay_us(16);
else
delay_us(16);
output_low(PIN_C5);
delay_us(12);
output_low(PIN_C5);
delay_us(50);
delay_ms(250);
output_low(PIN_C5);
wait_a_second(2);
test4_flag=1;
break;
case 5:
test5_flag=0;
output_low(PIN_C5);
delay_us(300);
output_low(PIN_C5);
delay_us(10);
for (i=0;i<16;i++)
if (cmd1==0)
delay_us(2);
output_low(PIN_C5);
delay_us(16);
else
delay_us(16);
output_low(PIN_C5);
delay_us(12);
output_low(PIN_C5);
delay_us(50);
delay_ms(20);
output_low(PIN_C5);
delay_ms(20);//1
delay_ms(20);
output_low(PIN_C5);
delay_ms(20);//2
delay_ms(20);
output_low(PIN_C5);
delay_ms(20);//3
delay_ms(20);
output_low(PIN_C5);
delay_ms(20);//4
delay_ms(20);
output_low(PIN_C5);
delay_ms(20);//5
wait_a_second(2);
output_low(PIN_C5);
test5_flag=1;
break;
case 6:
test6_flag=0;
output_low(PIN_C5);
delay_us(300);
output_low(PIN_C5);
delay_us(10);
for (i=0;i<16;i++)
if (cmd1==0)
delay_us(2);
output_low(PIN_C5);
delay_us(16);
else
delay_us(16);
output_low(PIN_C5);
delay_us(12);
output_low(PIN_C5);
delay_us(50);
delay_ms(20);
output_low(PIN_C5);
// I need to make changes for the specs
delay_ms(20);//1 signal 5
delay_ms(20);
output_low(PIN_C5);
delay_ms(20);//2
delay_ms(20);
output_low(PIN_C5);
delay_ms(20);//3
delay_ms(20);
output_low(PIN_C5);
delay_ms(20);//4
delay_ms(20);
output_low(PIN_C5);
delay_ms(20);//5
delay_ms(60);
delay_ms(250);
wait_a_second(2);
output_low(PIN_C5);
test6_flag=1;
break;
}// switch
}//main
Can someone help with the problem? I am using the PCH c compiler.
Thanks a lot,
Hi all,
I haven't programmed GLCD in any language except mikroBASIC or mikroC, where the internal library is one great help.
Sorry for being slightly offtopic. (Moderators: I am not advertising for mikroE, just telling my experience)
Tahmid said:
Hi all,
I used to use MPLAB for PIC assembly, so I got addicted to Microchip software in time. I always wondered how it is to write code in microC and Hi-Tech. You said microC had internal libraries, that is one good feature, I would like to try it, but later...
Hi hkBattousai,
Yea, I used to program in assembly in MPLAB at first. Loved it, but then I realized how long it took to develop longer, more complex programs. It's quite a tedious job. In that respect mikroC is better.
I use mikroBASIC almost all the time, mikroC only when required, but they are quite similar as they share the same libraries and I have an understanding of both BASIC and C languages.
You should give mikroC or mikroBASIC a try, you're gonna love it.
Hi-Tech, don't know, never used it, but I used C18 and C30. They're not bad, but I like mikroC better.
Tahmid.
    hkBattousai
Hitech C is also a nice one..
It also has internal libraries for EEPROM, UART etc.. And the free version has only the limitations on optimisations.
I didnt even learn PIC assembly language, but was programming 8051 in assembly.
hi, I'm using PIC18F2550 to interface my 16x2 text LCD..I've tried so many source codes including the one in MikroC library..the circuit is just like the one in LCD_library (4-bit interface) but the word didn't show up..could anyone help me with this? :(
Upload your circuit and code.
it's working now~ :) the problem was due to the connection of the LCD pins to my stripboard..
