niteshtripathi
Member level 3
sir, I am trying to do following -
I am giving a signal x(t) as input which has 1000 samples.(i have taken one signal and samples it using the matlab and got the points in form of integars)
Now i have extracted the local maxima and minima of that signal.
By using local maxima i have calculated the upper envelope by using linear interpolation and same i have done with local minima to calculate the lower envelope and then i have taken the average of the upper and lower envelope and have got a signal m(t)
now i have to calculate a new signal h(t) which will be
h(t) = x(t) - m(t)
I have to repeat all above three times, means now again h(t) will be the input signal,
x(t) = h(t)
How to repeat the steps? I have written the code separately for each step. Should i use FSm? If i am going to use FSMs then how can i instantiate the modules in FSMs? Please suggest. I ma in big trouble
[accessed Nov 9, 2015].
h(t) = x(t) - m(t)
x(t) = h(t)
