problem in USB to serial converter with isolation
PRIYADHARSHINI PALANISAMY
Member level 2
Member level 2
i m using usb to RS-232/485 to acquiring the Data..when i connect the converter to the PC
it indicate the port number in Device manager.but when i am trying to connect it through moDbus poll it inDicates that "port not available".what is the reason for this issue?:?:
Look in the device manager if there is a "microsoft ballpoint mouse" is installed.
Sometimes i have problems with that. An FTDI chip is recognized and it shows the correct com port, but immediately the wrong mouse driver catches the port or the data.
The solution is to disable the ballpoint mouse driver in device manager.
Hope this helps
Klaus
yes.i used the converter in hyperterminal anD VB.In hyperterminal i DiD nt face any problem.In VB sometimes it shows "port not available".some times it works properly
