hello to all ( first post )
i wanted to check a 2SC3052F and 2SA1235F in this schematic ( An AIWA HiFi )
when they tested (even out of board) everything is ok except that about 1000 ( multi tester in diode test mode ) between collector and emitter (in just one way) .
are they really broken ?
if yes would you please help this newbie with poor english with some equivalents?!
thanks in advance
If you need a real good transistor tester you don't need to take it off the board and it will check diode and other electronic parts as well let me no and I will send you the detail how to make it
