Problem in taking users's inputs ~
Tarneem
Newbie level 6
Hi ;
I m facing problem in taking inputs from the user by using push buttons ~
Here is the code of the function that taking from the user the inputs ..
(inc= increments , Dec= decrements , Next to exit )
Timerr() // set Timer
 k=1;
 minutes=0;
 while(K!=6)
   if(inc==0)
      {minutes++;
      Lcd_Cmd(0xc0);
      Lcd_Out_Cp(minutes);
    if(dec==0)
       minutes=minutes--;
       Lcd_Cmd(0xc3);
   if(next==0)
   {k=6;while(next==0);}
this is just to have the input form the user ,, but in each time that i clicked , it shows me garbage values ..
Any one can help ..??
Plz :-(
Vbase
Full Member level 6
When you click inc or dec the minutes keep on counting and displaying new value while your finger is on the button.
Add this kind of line while(next==0);
mdorian
Member level 2
Romania
You also have to skip push button transitions
Maybe something like this would be better:
 k=1;
 minutes=0;
        Lcd_Cmd(0xc0);
        Lcd_Out_Cp(minutes);// to see something if no button pressed
 while(K!=6)
   while(inc==0)
      {minutes++;
        Lcd_Cmd(0xc0);
        i=0
        do {
           delay_ms(100);//  small delay to skip transitions
           i++;
            } while ((i<5) & (inc==0))// repeat with long delay if button still pressed
betwixt
Super Moderator
Staff member
Aberdyfi, West Wales, UK
Just as important - what value is 'minutes' to start with?
To work as text on an LCD you can't just use 0 to 9, you have to use 0x30 to 0x39 (48 to 57 in decimal) and maybe cater for numbers outside that range too.
Brian.
mdorian
Member level 2
Romania
I missed that ,if you're using MikroC ,a string must be passed to Lcd_Out_Cp.
Use a conversion function like ByteToStr
char txt[4];
 ByteToStr(minutes,txt);
        Lcd_Cmd(0xc0);
        Lcd_Out_Cp(txt);
assuming that minutes is a char
Tarneem
Newbie level 6
sir , It's give me better result ..
peevishly it was shown me garbage values .. but now it shows numbers only .. ^_^
Thank u so muuuuch mdorian and every one else helped ..
but still i m having problem .. now see .. this is the initialization
 char seconds = 0;
  char minutes = 0;
  char i;
  char txt[4];
and this is the function of timer in main :
if(Timer==0)    //check Timer set button press
    Lcd_Cmd(_LCD_CLEAR);
    Lcd_Out(1,2,"Countdown  ");
    Timerr();    //call Timer set function
and her is the function Timerr():
 k=1;
        minutes=0;
        Lcd_Cmd(0xc4);
        ByteToStr(minutes,txt);// to see something if no button pressed
 while(K!=6)
   if(inc==0)
      { minutes++;while(inc==0);
        Lcd_Cmd(0xc4);
        Lcd_Out_Cp(txt);
    if(dec==0)
       minutes--; while(inc==0);
        Lcd_Cmd(0xc4);
        Lcd_Out_Cp(txt);
   if(next==0)
The problem is when i first ckliked inc buttons , it shows mw 46 then i cliked again it shows 78 then 22 then 53 ...
What do u think the problem can be ? ?
IT woooooooorks ..
Thanks for every body who helped me .. I m really thankful to u ppl so much
Yes .. I m using MikroC program ,, and this is the initialization data :
This is the if statment in main function :
char seconds = 0;
  char minutes = 0;
  char i;
  char txt[4];
if(Timer==0)    //check alarm set button press
    for (i=60; i >= 0; i--)
    seconds = i;
    minutes = i / 60;
    seconds = seconds - (minutes * 60);
       Delay_ms(500);
    IntToStr(seconds, txt);
    Lcd_Out(2, 5, txt);
    IntToStr(minutes, txt);
    Lcd_Out(2, 1, txt);
    Delay_ms(100);
and this is the Timerr() function :
 k=1;
        minutes=0;
        Lcd_Cmd(0xc4);
 while(K!=6)
   if(inc==0)
        Lcd_Cmd(0xc4);
        Lcd_Out_Cp(txt);
    if(dec==0)
       minutes--; while(dec==0);
        Lcd_Cmd(0xc4);
        Lcd_Out_Cp(txt);
   if(next==0)
I want to take the minutes that is taken from the user and start the countingdown function ..
the role that i wrote is nor function right ..
minutes = i / 60;
Any one can suggest me a good way to do that ?
Thank u so much again .. i really appreciated
Vbase
Full Member level 6
if(seconds == 60)
seconds = 0;
minutes++;
Brian.
It's a countdown;
if(seconds == 255)
seconds = 59;
minutes--;
Brian, I believe you can improve on this code.
Tarneem
Newbie level 6
IT dowsn't work by this way =(
I m working now by this way ..
But I m having problem ..
when I entered 4 munits .. It show in LCD 3 : 59 and stopped .. it is not conteniously decreasing
    while (minutes)
    minutes--;
        Lcd_Cmd(0xc2);
        Lcd_Out_Cp(txt);
       for ( i=59 ; i>0 ; i-- )
       seconds = 59;
       byteToStr(seconds,txt);
       Lcd_Cmd(0xc6);
       Lcd_Out_Cp(txt);
       Delay_ms(500);
       seconds--;
        if (seconds==0)
           {minutes--;
        Lcd_Cmd(0xc2);
        Lcd_Out_Cp(txt);}
DOOOOOOONE ..
the problem has been fixed .. ALHamduleAllah .. ~
Thank u so much for ur help ..
I really thankfull to u ALL .. ~
