Problem in reuse -PADS 2005
Monolisa5791
Member level 3
Member level 3
pads 2005 reuse
Hi All,
I am using pads 2005 sp2 I need to reuse the traces from one design to another design.I have tried it with the REUSE option in PADS. Traces comes and place in the exact location of the center of the drill and also the location of traces matches. But still TACKS are showing in the entry of the PAD and connectivity doesn't comes. Let us know anyone how to solve this problem.
Regards,
Monolisa
reuse design
Just export the ASCII from the board file after reuse and agian import the ASCII in to the board file.
pads pcb reuse 2005
First, select the traces needs to be reused and save that resue file. After that select the option "reset origin" and select the origin 0,0. again save that reuse file.
In your new board, use that reuse section with the origin of 0,0. It will work.
