problem in programmable
pic16f84
Member level 4
libya
hi
i have problem in mmy programmable whe complate write to pic end after doind error in verfiy inand this error 0000h line
Salam,
The 0000h Error is either for that the ports are not currently opened OR it is probably for an error in the programming circuit
Hope That Helps
Regards,
Check vpp and ensure it's 12.75-13.5v
check load on RB6 and RB7( SCLK&SDATA) if there is any load like LED remove it while programming.
Check for filter capacitors in VDD or VPP, remove if it's more than 47MFD.
hope it will solve your problem.
