Problem in MPLAB with ICD2 made using LM358
xmli1976
Full Member level 1
Full Member level 1
I made a icd2 by myself,the schematic is from www.stolz.de.be using LM358.
but it doesn't work.
when connecting this icd2,the output windows display the following results :
Auto-connect not enabled - Not connecting (Try enabling auto-connect on the ICD2 settings pages.)
ICDWarn0034: Please ensure that your system's serial FIFO buffers are disabled.
Connecting to MPLAB ICD 2
ICD0021: Unable to connect with MPLAB ICD 2MPLAB ICD 2 ReadyDownloading Operating System
...Download Operating System FailedICD0029: Connected tool is not an MPLAB ICD 2: Product ID = 0x0 (MPLAB ICD (1))
ICD0082: Failed MPLAB ICD 2 operation
ICDWarn0054: MPLAB IDE has lost communications with the MPLAB ICD 2. Would you like to attempt to reconnect?
ICD0082: Failed MPLAB ICD 2 operationICD0082: Failed MPLAB ICD 2 operation
MPLAB ICD 2 Ready
ICD0286: Unable to communicate with ICD
MPLAB ICD 2 Ready
could any help me?
Added after 1 minutes:
I'm using mp lab7.30
lm 358 how to connect
Hai
One of my friends has done this ICD ,and he told me that for him it was working only in MPLAB7.1.
Keep this information in mind and verify if possible.
Make sure by any means weather the PIC is really got programmed with the bootloader and is there any incompatability between MPLAB and the hardware and firmware.
from the message it is giving a feel that MPLAB "see" some device but it is not what it expects.
Carefully check version issues!
picstudent
connected tool is not an mplab icd 2
Hi, I built the same design, and it gave me similar problem. I changed the MCU from 16F877-20 to 16F877A and uploaded the firmware for 16F877A, found on Blueroomelectronics Inchworm kit, you can download it from there.
Its working perfect, everything, including debugging.
I may Add here that I am using MPLAB 8 and its working excellent.
using lm358
Hello,
I had problems with this circuit too.. but it works. Try the ICD661.zip. MPLAB indicate size error with the firmare BL010101.hex and 877A.
Check the MCLR, I am using a clamp circuit from the DTR pin.
Change the settings of the serial COM that you are using to HARDWARE control (use the help of the MPLAB ) and the "FIFO" message will disapear.
I used the MPLAB 7.2.
ARS
"When someone evolve, evolves everything that is around them" - The Alchemist
