problem in matlab simulink
mohamed mahmoud
Junior Member level 1
what i can do ??
Obviously you can't! Pulse generator signal output type is incompatible with CMOS Buffer and D-FF. For the D-FF you can insert a data type conversion block. For the CMOS buffer you have to use sources from the SimElectronics toolbox only.
HOPEFULLY if you take a snapshot to what you have said
thanks in advance
It's clear enough, don't think a snapshot is necessary! Go to simulink library and search for: 1. data type conversion 2. SimElectronics and have a look at the sources.
