Problem in externa interrupt in 16f877
ecaits
Member level 4
Member level 4
I want to use external interrupt in pic16f877 but cannot get the interrupt. Code is given below.
Why it is not getting ???
I am using switch on RB0 pin and want to toggle the RB1 pin connected with LED.
Plz support.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
#include<htc.h>
#include<pic.h>
void main()
    TRISB0=1;
     TRISB1=0;                    // Configure PortD as output port
 //   INTCON=0x90;                  // Enable INT0
//    INTCON2=0;                    // Set Falling Edge Trigger for INT0
GIE = 1;
INTE = 1;
OPTION = 0x40;
 //   INTCON.GIE=1;    // Enable The Global Interrupt
    while(1)
   //     LATB=0x55;       //Set some value at PortD
void interrupt ISR(void)              // Interrupt ISR
    if(INTF==1)
    INTF=0;          // Clear the interrupt 0 flag
    RB1=~RB1;  }             // Invert (Toggle) the value at PortD
  //  Delay_ms(1000);           // Delay for 1 sec
What IDE and compiler are you using? Have you tried putting the interrupt above the main function? I am not sure if you need that OPTION call, I don't believe I used that before when I did interrupts. What are your configuration bits?
