[AVR] problem in atmega8....
Deexith Hasan
Full Member level 1
a simple program on timer1 to get 1sec delay and successfully compiled in winavr.. but got error push program stack:SP is not initialized .. in proteus....
how to solve it.........
#include <avr/io.h>
#include <util/delay.h>
  void delay();
  void main(void)
    SPH=0X00;
	SPL=0X00;
    DDRB=0XFF;
    while(1)
	PORTB=0X00;
	delay();
	PORTB=0XFF;
	delay();
   void delay()
TCNT1H=0X85;
TCNT1L=0XEE;
TCCR1A=0X00;
TCCR1B=0X04;
  while((TIFR& (0X1<<TOV1))==0);
TCCR1B=0X00;
  TIFR=0x1<<TOV1;
Here is mikroC PRO AVR Code.
It uses Timer to get 1 second delay. LEDs are connected to PORTB.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
char count = 0;
//Timer1 Prescaler = 64; Preload = 31249; Actual Interrupt Time = 500 ms
//Place/Copy this part in declaration section
void InitTimer1() {
    SREG_I_bit = 1;
    TCCR1A = 0x80;
    TCCR1B = 0x0B;
    OCR1AH = 0x7A;
    OCR1AL = 0x11;
    OCIE1A_bit = 1;
void Timer1Overflow_ISR() org IVT_ADDR_TIMER1_COMPA {
    //Enter your code here
    if(++count == 2) {
         count = 0;
         PORTB = ~PORTB;
void main() {
    DDRB = 0xFF;
    DDRC = 0xFF;
    DDRD = 0xFF;
    PORTB = 0x00;
    PORTC = 0x00;
    PORTD = 0x00;
    InitTimer1();
    while(1) {
          asm nop
broken link removed
  • Timer Based LED Blinking.rar
  • Atmel Studio.rar
thats k....for atmega16 & 32 got gud result in proteus only for atmega8 y?? what does it mean error push program stack:SP is not initialized
SP not initialized means Stack Pointer not initialized. Why are you clearing the stack pointer in the code. Don't do anything with stack pointer. Here I am attaching LED Blinking code made for different AVR Compilers.
  • LED Blinking.rar
i removed the SP again faced the same problem....
SPH=0X00;
SPL=0X00;
y????
Unistall Atmel Studio and install the latest version which is v6.2 and try.
