[SOLVED] problem in ADC for AVR (ADC result lost due to pending read)
mahm150
Full Member level 1
Cairo, Egypt, Egypt
this message appear in proteus ADC result lost due to pending read
#define ADC_VREF_TYPE 0x40
ADMUX=ADC_VREF_TYPE;
ADCSRA=0x82;
i use this function
unsigned int read_adc(unsigned char adc_input)
ADMUX=adc_input|ADC_VREF_TYPE;
// Start the AD conversion
ADCSRA|=0x40;
// Wait for the AD conversion to complete
while ((ADCSRA & 0x10)==0);
delay_us(100); // make this delay but not solve this problem
ADCSRA |=0x10;
Tadc=(Tadc<< 8)| ADCL;
return ADCW;
Tahmid
Advanced Member level 5
Silicon Valley, California, USA (from Dhaka, Bangl
It would be more helpful if you could upload the complete code. You also need to mention which AVR you're using.
I've tried with this code for ATMEGA8:
#include <avr/io.h>
#include <avr/delay.h>
ADMUX= ADC_VREF_TYPE | adc_input;
ADCSRA|=0x40;
_delay_us(100); // make this delay but not solve this problem
ADCSRA |=0x10;
//Tadc=(Tadc<< 8)| ADCL;
return ADCW;
main(){
    unsigned int ADR;
    ADCSRA=0x82;
    DDRD = 0xFF;
    DDRC = 0;
    do{
        ADR = read_adc(1) >> 2;
        PORTD = ADR;
    }while(1);
And it's fine. The line:
doesn't build properly as there is no register or variable named Tadc.
Hope this helps.
Tahmid.
mahm150
Full Member level 1
Cairo, Egypt, Egypt
i define the Tadc as global variable
unsigned int Tadc;
void main(void)
while (1)
Tadc=read_adc(0) ;
tst_value();
ADCSRA|=0x40;
delay_us(100);
ADCSRA |=0x10;
// Tadc=(Tadc<< 8)| ADCL;
return ADCW;
void tst_value()
if (Tadc<410)
relay1 =0;
relay2 =1;
TCCR1B=0x19;
OCR1AH=0x01;// 1
OCR1AL=0xff;// ff
PORTD |= (ADCL & 0x7c);
// if (615>Tadc && Tadc>410)
// { TCCR1B=0x00; }
if (Tadc>=460)
relay1 =1;
relay2 =0;
TCCR1B=0x19;
OCR1AH=0x00;// 1
OCR1AL=0xff;// ff
PORTD|=ADCL & 0x7f;
---------- Post added at 19:06 ---------- Previous post was at 19:05 ----------
#define relay1 PORTB.0
#define relay2 PORTD.7
mahm150
Full Member level 1
Cairo, Egypt, Egypt
i use atmega8
i still have some problem in PWM but let solve this problem first
---------- Post added at 19:10 ---------- Previous post was at 19:09 ----------
codevisionAVR
Tahmid
Please wait. I'm downloading CodeVision AVR. After I'm done, I'll try to fix the problem in the program.
---------- Post added at 01:00 ---------- Previous post was at 00:13 ----------
I've fixed the code. This shows no error and the program works. However, I do not understand what you are trying to do in PORTD.
#include <mega8.h>
#include <delay.h>
#include <stdio.h>
unsigned int Tadc;
unsigned char dummyH;
unsigned char dummyL;
unsigned int read_adc(unsigned char adc_input){
    ADCSRA.ADSC = 1;
    while (ADCSRA.ADIF==0);
    ADCSRA.ADIF = 1;
    dummyL = ADCL;
    dummyH = ADCH;
return ADCW;
void tst_value(){
    if (Tadc<410){
        relay1 =0;
        relay2 =1;
        TCCR1B=0x19;
        OCR1AH=0x01;// 1
        OCR1AL=0xff;// ff
        PORTD |= (dummyL & 0x7c);
    // { TCCR1B=0x00; }
    if (Tadc>=460){
        relay1 =1;
        relay2 =0;
        TCCR1B=0x19;
        OCR1AH=0x00;// 1
        OCR1AL=0xff;// ff
        PORTD|=dummyL & 0x7f;
void main(void){
    DDRC.0 = 0;
    DDRD = 0xFF;
    DDRB.0 = 1;
    ADCSRA=0x82;
    while (1){
        Tadc=read_adc(0);
        tst_value();
Hope this helps.
Tahmid.
mahm150
Full Member level 1
Cairo, Egypt, Egypt
i use PORTD JUST TO SEE THE VALUE OF the adc register,about my problem it appear with me in protues (ADC result lost due to pending read), what the error in my code
---------- Post added at 18:53 ---------- Previous post was at 18:50 ----------
you test this code in protues
mahm150
Full Member level 1
Cairo, Egypt, Egypt
not yet but i will test it, but i didnt find the main difference in my code and the code you post so where is the problem
mahm150
Full Member level 1
Cairo, Egypt, Egypt
ADCSRA.ADSC not define in codevision
and ADCSRA.ADIF which code vision version you use
alexan_e
Administrator
Greece
Try it. There's a difference. Try it and then I'll show the difference.
Why is it a secret?
I have never seen anything like that in codevision
Alex
Tahmid
I used CodeVision AVR v2.05.3a Evaluation Version. Here's a screenshot:
The difference is, in the previous program, the function returns the value of ADCW and then ADCL is read, however ADCH is not read. But in my program, in the ISR, both the values of ADCH and ADCL are stored in registers, so a complete read is done.
From the datasheet (pg 208):
When ADCL is read, the ADC Data Register is not updated until ADCH is read. Consequently, if
the result is left adjusted and no more than 8-bit precision is required, it is sufficient to read
ADCH. Otherwise, ADCL must be read first, then ADCH.
Why is it a secret?
I was writing another program and thought that I'd explain after he'd tried out the program. Anyways, I showed the difference now. So, all's good.
Hope this helps.
Tahmid.
alexan_e
Administrator
Greece
The code generated by codevision is
Code C - [expand]
8
9
10
11
12
13
// Read the AD conversion result
ADMUX=adc_input | (ADC_VREF_TYPE & 0xff);
// Delay needed for the stabilization of the ADC input voltage
delay_us(10);
ADCSRA|=0x40;
ADCSRA|=0x10;
return ADCW;
I don't see the reason to do the dummy reads of the high and low byte, the code below works fine
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
#include <mega8.h>
#include <delay.h>
#define ADC_VREF_TYPE 0x00
    delay_us(10);
    ADCSRA|=0x40;
    ADCSRA|=0x10;
    return ADCW;
// Declare your global variables here
void main(void)
// ADC initialization
// ADC Clock frequency: 125,000 kHz
// ADC Voltage Reference: AREF pin
    ADMUX=ADC_VREF_TYPE & 0xff;
    ADCSRA=0x86;
    while (1)
        // Place your code here
        read_adc(0);
        delay_ms(1);
mahm150
Full Member level 1
Cairo, Egypt, Egypt
for tahmid i update the code as
ADCSRA|=0x40;
ADCSRA|=0x10;
dummyL=ADCL;
dummyH=ADCH;
return ADCW;
but still the same problem
and for alexan_e i test your code but give the smae error
alexan_e
Administrator
Greece
Then it is your proteus version because in version 7.7 there is no warning and the code I have posted works fine.
Alex
mahm150
Full Member level 1
Cairo, Egypt, Egypt
i test my code in real world but not work ok, i think that adc make only one conversion then not work after that,
alexan_e
Administrator
Greece
Can you zip and attach the code, I have only seen parts of the code in the previous posts.
Alex
mahm150
Full Member level 1
Cairo, Egypt, Egypt
#include <mega8.h>
#include <delay.h>
unsigned int Tadc;
unsigned char dummyH,dummyL;
//void intialize_adc(void);
unsigned int read_adc(unsigned char adc_input);
void tst_value(void);
interrupt [15] void ADC_READ(void)
ADCSRA |=0x10;
// PORTB=ADCH ;
// while(1);
void main(void)
// Declare your local variables here
PORTB=0x00;
DDRB=0xff;
PORTC=0xFF;
DDRC=0x00;
PORTD=0x00;
DDRD=0xff;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: 11059.200 kHz
// Mode: Fast PWM top=FFh
// OC0 output: Non-Inverted PWM
TCCR0=0x6b;
TCNT0=0x00;
//OCR0=0x71;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// Mode: Normal top=FFh
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
SREG=0X80;
ACSR=0x80;
SFIOR=0x00;
ADCSRA=0x82;
relay1 =0;
relay2 =1;
//intialize_adc();
//PORTB=0xa0;
while (1)
//intialize_adc();
Tadc=read_adc(0) ;
tst_value();
ADCSRA|=0x40;
ADCSRA|=0x10;
dummyL=ADCL;
dummyH=ADCH;
return ADCW;
void tst_value()
if (ADCL<128)
relay1 =0;
relay2 =1;
TCCR1B=0x19;
OCR1AH=0x01;// 1
OCR1AL=0xff;// ff
if (ADCL>=128)
relay1 =1;
relay2 =0;
TCCR1B=0x19;
OCR1AH=0x00;// 1
OCR1AL=0xff;// ff
PORTD|=ADCL & 0x7f;
alexan_e
Administrator
Greece
If you use Tadc in the tst_value() it works fine, the problem is caused by ADCL reading
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
void tst_value()
    if (Tadc<128)
        relay1 =0;
        relay2 =1;
        TCCR1B=0x19;
        OCR1AH=0x01;// 1
        OCR1AL=0xff;// ff
        //PORTD |= (ADCL & 0x7c);
    if (Tadc>=128)
        relay1 =1;
        relay2 =0;
        TCCR1B=0x19;
        OCR1AH=0x00;// 1
        OCR1AL=0xff;// ff
        //PORTD|=ADCL & 0x7f;
Alex
