digital design
Junior Member level 2
Hi every body
I have bellow code:
I have bellow errors in synthesize:
first error is about this line of code :
3 is in range but I can't find out reason of errors..!!
please help me....
I have bellow code:
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 -- Four-bits divider library IEEE; use IEEE.std_logic_1164.all; entity Divider_nBits is generic(N : integer :=4); port ( divisor : in std_logic_vector(N-1 downto 0); -- divisor dividend : in std_logic_vector(2*N-2 downto 0); -- dividend remainder : out std_logic_vector(N-1 downto 0); -- remainder quotient : out std_logic_vector(N-1 downto 0) -- quotient ); end entity ; ---------------------- Architecture Section ---------------------------------- architecture Stractural of Divider_nBits is --------------- Signal Declarations for instantiate type c_array is array (0 to N-1) of std_logic_vector(0 downto N) ; type r_array is array (0 to N-1) of std_logic_vector(0 downto N-1); signal sig_r : r_array ; signal sig_c : c_array ; begin -- Instantiate N single-bit controlled add/subtract LGEN: for i in 0 to N-1 generate LGEN2: for j in 0 to N-1 generate First_column:if j=0 and i/=N-1 generate CAS_i3:entity work.CAS(ADD_SUB) -- First Column port map ( divisor => divisor(j) , reminder_in => dividend(j) , T => not sig_r(i+1)(N-1) , cin => sig_c(i)(j) , reminder_out => sig_r(i)(j) , cout => sig_c(i)(j+1) ); end generate; Last_stage: if i=N-1 and j/=0 generate -- Last row CAS_ij:entity work.CAS(ADD_SUB) port map ( divisor => divisor(j) , reminder_in => dividend(j+N-1) , T => '1' , cin => sig_c(i)(j) , reminder_out => sig_r(i)(j) , cout => sig_c(i)(j+1) ); end generate; other_stage: if i/=N-1 and j/=0 generate -- others CAS_i2:entity work.CAS(ADD_SUB) port map ( divisor => divisor(j) , reminder_in => sig_r(i+1)(j-1) , T => not sig_r(i+1)(N-1) , cin => sig_c(i)(j) , reminder_out => sig_r(i)(j) , cout => sig_c(i)(j+1) ); end generate; end generate; end generate; end ;
ERROR:HDLCompiler:1315 - Line 38: Index value <3> is out of range [0:3]
ERROR:HDLCompiler:1315 - Line 39: Index value <0> is out of range [0:4]
ERROR:HDLCompiler:1315 - Line 40: Index value <0> is out of range [0:3]
ERROR:HDLCompiler:1315 - Line 41: Index value <1> is out of range [0:4]
N-1 = 3
please help me....
