fpganovice
Newbie level 1
- Joined
- Oct 13, 2013
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 38
Forgive me, I'm sure there is a simple solution to this but I am still very much a beginner with VHDL and am learning as I go along for a Digital Design course I'm currently taking. I'm running into a weird compiling error and was hoping I could get some help sorting through this. I have pasted the testbench and code I am testing underneath. I would greatly appreciate any form of assistance.
I'm trying to compile a testbench on ModelSim and I'm getting the following error:
Unknown formal identifier "WIDTH". The ModelSim compiler cites the line I typed out in red as providing the error.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity gcd_tb is
end gcd_tb;
architecture TB of gcd_tb is
constant WIDTH : positive := 16;
constant TIMEOUT : time := 1 ms;
signal clkEn : std_logic := '1';
signal clk : std_logic := '0';
signal rst : std_logic := '1';
signal go : std_logic := '0';
signal done : std_logic;
signal x : std_logic_vector(WIDTH-1 downto 0) := (others => '0');
signal y : std_logic_vector(WIDTH-1 downto 0) := (others => '0');
signal output : std_logic_vector(WIDTH-1 downto 0);
begin
UUT : entity work.gcd(FSM_D1)
generic map (
WIDTH => WIDTH)
port map (
clk => clk,
rst => rst,
go => go,
done => done,
x => x,
y => y,
output => output);
clk <= not clk and clkEn after 20 ns;
process
function GCD (x, y : integer)
return std_logic_vector is
variable tmpX, tmpY : integer;
begin
tmpX := x;
tmpY := y;
while (tmpX /= tmpY) loop
if tmpX < tmpY then
tmpY := tmpY-tmpX;
else
tmpX := tmpX-tmpY;
end if;
end loop;
return std_logic_vector(to_unsigned(tmpX, WIDTH));
end GCD;
begin
clkEn <= '1';
rst <= '1';
go <= '0';
x <= std_logic_vector(to_unsigned(0, WIDTH));
y <= std_logic_vector(to_unsigned(0, WIDTH));
wait for 200 ns;
rst <= '0';
for i in 0 to 5 loop
wait until clk'event and clk = '1';
end loop; -- i
for i in 1 to 2**WIDTH-1 loop
x <= std_logic_vector(to_unsigned(i, WIDTH));
for j in 1 to 2**WIDTH-1 loop
go <= '1';
y <= std_logic_vector(to_unsigned(j, WIDTH));
wait until done = '1' for TIMEOUT;
assert(done = '1') report "Done never asserted." severity warning;
assert(output = GCD(i, j)) report "Incorrect GCD" severity warning;
go <= '0';
end loop;
end loop;
clkEn <= '0';
report "DONE!!!!!!" severity note;
wait;
end process;
end TB;
library ieee;
use work.ctrl1_package.all;
use work.datapath1_package.all;
entity gcd is
generic (
WIDTH : positive := 16);
port (
clk : in std_logic;
rst : in std_logic;
go : in std_logic;
done : out std_logic;
x : in std_logic_vector(WIDTH-1 downto 0);
y : in std_logic_vector(WIDTH-1 downto 0);
output : out std_logic_vector(WIDTH-1 downto 0));
end gcd;
architecture FSM_D1 of gcd is
signal x_sel, x_en : std_logic;
signal y_sel, y_en : std_logic;
signal x_lt_y, x_ne_y : std_logic;
signal output_en : std_logic;
signal tmpX,tmpY : std_logic_vector(WIDTH-1 downto 0);
signal xBuff,yBuff : std_logic_vector(WIDTH-1 downto 0);
signal XsubY,YsubX : std_logic_vector(WIDTH-1 downto 0);
begin
Datapath: datapath1 port map(
x => x,
y => y,
clk => clk,
output => output);
Ctrl : ctrl1 port map(
clk => clk,
x_lt_y => x_lt_y,
x_ne_y => x_ne_y,
x_sel => x_sel,
x_en => x_en,
y_sel => y_sel,
y_en => y_en,
output_en => output_en);
end FSM_D1;
library ieee;
package gcd_package is
component gcd
generic (
port (
clk : in std_logic;
rst : in std_logic;
go : in std_logic;
end component;
end gcd_package;
Thanks alot for any help!
Also, please let me know if there is other information I should provide as this is my first post on the forum.
library ieee;
entity gcd_tb is
end gcd_tb;
begin
generic map (
WIDTH => WIDTH)
port map (
clk => clk,
rst => rst,
go => go,
done => done,
x => x,
y => y,
output => output);
process
begin
tmpX := x;
tmpY := y;
if tmpX < tmpY then
tmpY := tmpY-tmpX;
else
tmpX := tmpX-tmpY;
end if;
end loop;
end GCD;
begin
clkEn <= '1';
rst <= '1';
go <= '0';
wait for 200 ns;
rst <= '0';
end loop; -- i
go <= '1';
go <= '0';
end loop;
end loop;
clkEn <= '0';
wait;
end process;
end TB;
library ieee;
entity gcd is
generic (
port (
clk : in std_logic;
rst : in std_logic;
go : in std_logic;
end gcd;
begin
x => x,
y => y,
clk => clk,
output => output);
clk => clk,
x_lt_y => x_lt_y,
x_ne_y => x_ne_y,
x_sel => x_sel,
x_en => x_en,
y_sel => y_sel,
y_en => y_en,
end FSM_D1;
library ieee;
component gcd
generic (
port (
clk : in std_logic;
rst : in std_logic;
go : in std_logic;
end component;
end gcd_package;
