Probelm with NC drill import in CAM350
KSA
Junior Member level 2
cam350 nc drill
I have a probelm with NC drill format after I export it using PowerPCB (from Innoveda). When I try to import it using either CAM350 or GerbTool, it cannot import the tool table.
Could you help?
KSA
JURS
Member level 2
Member level 2
import drill file cam 350
Hi KSA,
for import the tool table you must use macro P A D S drill.
JURS
Antonios
Banned
Member level 4
Cairo
cam 350 drill import
Check the output format from Ur tool it must be as Import format to import Drill Correctly
Alexj
Junior Member level 1
cam350 nc table import
Why cann't you input the drill database? If you use" File---import---autoImport,
it should input the gerber files automaticlly, if you cann't got the right graphic with drill , pls check the format and acuaccy, and then, when you re-import the gerber file, pls select "next" , and then find the drill file then select the format for it,
it should be ok for now.
