[SOLVED] Prob with input in C
bauche
Junior Member level 1
Hi there
a liitle prob in c
i have 2 input port A0 and port A1 i want to put on 1 led if both of them pressed (closed) together...i found out a solution but if 1 input is close
led not working ...but if my two input is close led goes on ...and when my two input is open led goes on too....
void main() {
ADCON1 |= 0x0F;
TRISA = 0xff;
TRISB = 0;
for(;;)
  if((RA0_bit=1)==(RA1_bit=1)) //if button is pressed
  RB4_bit=1;
  else
  RB4_bit=0;
Code C - [expand]
8
9
if((PORTA & 0x03) == 0x03)) //if button is pressed
    Delay_ms(50);
    while(PORTA & 0x03) == 0x03);
    RB4_bit= ~RB4_bit;
your if statement inside the main loop should be
if((RA0_bit==1) && (RA1_bit==1))
Thanks for all ....i finally found how to do it ....!!!
:grin:
