Sep 8, 2003 #1 T TiMe25 Newbie level 5 Joined Jan 26, 2002 Messages 9 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 27 So i need to transfare the schematic from protel dxp to ms word ..... any suggestion ho to do this?? I woud like to have the same size of conmponents no matter if circuit is large or small ... with alt+printscreen dont work?? TiMe25
Sep 8, 2003 #2 C crazyduck Full Member level 4 Joined Sep 3, 2001 Messages 214 Helped 13 Reputation 26 Reaction score 6 Trophy points 1,298 Location France Activity points 2,007 Hello, Use the CTRL+C command. You must select the components you to copy. Use the CTRL+C to copy them, go to Word and use the CTRL+V command. Be careful with the "preferences" menu of the schematic editor, uncheck the box "copy with template". CD
Sep 14, 2003 #3 Z zxfeng Member level 2 Joined Dec 27, 2001 Messages 51 Helped 7 Reputation 14 Reaction score 3 Trophy points 1,288 Activity points 268 use pdfWriter. print schematic to pdf file , convert pdf to jpg, then insert it
Sep 14, 2003 #4 T TiMe25 Newbie level 5 Joined Jan 26, 2002 Messages 9 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 27 Work very well with CTRL+C and CTRL+V Thakns, TiMe25
Sep 15, 2003 #5 S sygenics Junior Member level 2 Joined Jan 17, 2002 Messages 24 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 132 you can also goto print preview, then right click copy, or export metafile. this paste/import good into word! sygenics
