pes68
Junior Member level 3
- Joined
- Oct 1, 2010
- Messages
- 26
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,427
Sometimes I have the following error when trying to create netlist and
start simulation in Affirma Analog Circuit Enviroment:
*Error* fprintf/sprintf: format spec. incompatible with data - nil
After that netlist is not created, Spectre is not starting etc.. I am
using Cadence 5.14 The problem is that this error appears more or
less randomly - when you start a new design it can appear or not, but
once Spectre started wveruthing is ok - I can modify things and
simulate further on.. Similarly - once it has appeared, I can't do
anything
Has anyone met with similar things???
anything
