yamanoorsai
Newbie level 5
Hello All,
I bought a cheap pressure sensor from mouser whose datasheet can be found here:
http://www.components.omron.com/components/web/pdflib.nsf/0/DEFC0948FE2A5C91862577A7005A8099/$file/2SMPP_1010.pdf
The data sheet recommends a constant current circuit for the input and an instrumentation amplifier at the output.
I found a reference circuit in the link below:
http://www.meas-spec.com/downloads/A_Simple_Pressure_Sensor_Signal_Conditioning_Circuit.pdf
I am planning to use the LTC1051 for the constant current circuit and AD620 for the instrumentation amplifier. I would like to know whether this is the best way to read the output from the sensor or whether there is an alternative to this circuit. I am planning to choose LTC1051 from the reference circuit and AD620 since the second half of the circuit looks like a typical instrumentation amplifier circuit.
Also, the pressure sensor is really small and requires SMT soldering. I tried soldering it to a general purpose PCB board prototyping board but failed in doing so. I would like to hear the group members recommendation for soldering on top of a prototyping board.
Are there any low cost sensors apart from this Mouser one that has a linear output and could be used for Medical applications?
Thanks,
Sai
Thanks,
Sai
