vockleya
I have recently acquired an old hammond organ. This organ only has a 2-prong power plug. It has an internal ground that I measured at 0VDC, but 60VAC. I believe it is causing a large amount of hum in the speaker. The thing I am confused about is that the ground bus is connected to the center tap of a transformer. So shouldn't it be at 0VAC? Is there something I should do? Can I connect the internal ground to earth somehow? I have attached the schematic of the power supply section if you need it.
