Centmo
Member level 3
Hello, I'm an EE but a little out of element with power supply design, so I'm looking for some suggestions.
I need to charge a 14S LiPo as fast as possible from a standard 120V/20A wall plug. A fully charged pack is 4.2V * 14 = 58.8V. With the AC circuit able to supply up to 20A at 120Vrms (2400W), I figure that a DC supply could reasonably provide 30A at 60V from this circuit. Please assume that the battery pack can safely handle this charge current. The output voltage must be variable in the range 0-60V, so that I can implement a control loop to perform constant-current charging.
Ignoring the cell-balancing part of the problem (this will be done externally from the DC supply), where can I begin to design such a DC supply? I know it may have to be bulky, but the lighter, the better. Is there a development kit I can start from?
Thanks.
Thanks.
