freedelphi
Junior Member level 3
Power Saving Circuit
I need to design a circuit to do the followings :
Any Idea what kind of circuit do I need? (Filter? PF Corrector?)
TIA..
Protection:
Protect your entire electrical system and equipment from damaging externally and internally generated dirty electrical power.
Savings:
Ener/Tech provides a written warranty that its equipment cuts electrical (kwh) usage 20% or more. Filters out thermodynamics, which are heat causing, voltage stressing elements from the power line. Reducing the resistance on all electrical equipment and lights provides increased operating efficiency, and as a result uses less energy.
Longer Life:
Dirty electrical power bombards electrical circuits up to 400,000 times per hour. As a result, your electrical equipment is being gradually (sometimes suddenly) destroyed. Cleaning up dirty electrical power will increase the life span of your expensive electrical equipment.
TIA..
