HWguru
Junior Member level 2
- Joined
- Jan 20, 2015
- Messages
- 24
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 3
- Activity points
- 186
Hi ALL,
I am not an expert in analogue design , and i need to design a power amplifier to derive a air-core coil made up of 40 awg wire to create a strong magnetic field , its total impedance is 5ohm.
I have tried LM1875 , my input frequency is from 22hz to 32Hz square wave , but for some reason it gets hot and there is no output coming from it . The input oscillations are being generated from a 555 , but in future i intend to connect the LM1875 to a pure sinusoidal oscillator .
I need suggestions as to which op-amp are out there with some decent application notes and easy to use , because with LM1875 the TI datasheet dosent give reader with the BOM list , i couldnt figure the voltage rating and type of capacitor to use with it .
Thanks
Thanks
