power amplifier 40W output at 200Mhz.
vodanhtieutot
Newbie level 2
I have the problem when design RF 50W & 200Mhz power amplifier, because i knew some opamp can work at high frequency so i wonder i can use opamp (now i use AD8024) for power amplifier or using transistors (an9024), could anyone help me solve that problem?
goldsmith
Advanced Member level 5
Tehran - IRAN
Dear vodanhtieutot
Hi
Would you like that i introduce you , some better ways ?
Best Wishes
Goldsmith
davenn
Advanced Member level 3
Sydney, Australia
did you read the datasheet for the op-amp ? If so you would see that its not going to give 40-50W output. Its a very low level output.
for the power level that you require you are probably best to use at least a 2 or 3 stage amplifier so that the gain is evenly spread across all the devices and thereby retaining stability.
Have a look at some of the Mitsubishi power block modules, the RAxxxxxx series. They have a wide range of modules covering different frequencies and power levels.
Most will operate to full power out with ~ 100mW input.
Dave
tony_lth
Beijing
You can use banlanced configuration to get better width and VSWR.
vodanhtieutot
Newbie level 2
Would you please explain or tech me some circuit either get better width, VSWR or high power (40W) for frequency at 200Mhz.
---------- Post added at 19:11 ---------- Previous post was at 19:08 ----------
Dave
I think you right but my design is using opamp compine with Wikison hybrid circuit to get high power but i worry Wikison hybrid have large attenuation.
tony_lth
Beijing
I think That's impossible to use OpAmp to get 40W. If you can, could you give the part number of the OpAmp?
davenn
Sydney, Australia
exactly!! thats what I tried to tell the OP in an earlier post. The Op-amp he mentioned isnt going to do it. There are no Op-Amps that I'm aware of to produce hi power at any freq let alone 200MHz
I gave him an excellent suggestion but it seems to have been ignored
Dave
goldsmith
Tehran - IRAN
"think That's impossible to use OpAmp to get 40W"
Hi Dear All
for op amp , there are many selections e.g AD9631 or .... etc . but as the other said it is impossible to get this power from an op amp at this frequency .
I have a better suggestion .
Why op amp ? you can use Gali amp series . e.g gali-5 . see below , please :
https://www.minicircuits.com/pdfs/GALI-5+.pdf
It is a wide band amp that has 4 pins , and will send your amplified signal on supply . and you can lockout it with an RFC simply . and then you can use a class C or E or F as power amplifier after gali-5 . and with this simple way you can achieve your desired power .
Best Wishes
Goldsmith
---------- Post added at 11:05 ---------- Previous post was at 11:03 ----------
BTW : i forgot to say , that if your input signal is weak , you can use chain amplifiers that consist some gali-5 or some op amps . but some gali-5 will be better ( but if your signal is very weak , you'd better to use some op amps and then gali-5 and power amp .
davenn
Sydney, Australia
Yup there are a number of MMIC's like the GALI-5 that will produce enough power to drive various MItsubishi power block modules
Dave
