Potential Voltage drop issues in DC System
robismyname
Full Member level 6
Central Florida
I have a DC system that runs on 12VDC. In the system there is a very important component (DC to DC converter) that drives the power to my load.
I would like to know.
1) Voltage Drop across battery meter display? Is it just P=(V^2/R), solve for R then V=I*R, solve for V?
2) Voltage Drop across Device X.
3) Since Device X is not in series with the DC to DC converter like the Voltage meter display will this impact the input voltage of the DC to DC converter due to its voltage drop? Or will it just drain the battery faster?
There is a charging system in place to charge the battery for a certain threshold/condition.
"Voltage Drop across battery meter display?", to monitor the current (if it is displayed) a low value resistor is placed in series with the incoming line. Normally this is chosen to give a 100mV drop at full current range. It could be lower, see the manufacturers data for this unit.
"Voltage Drop across Device X." It is 12V.
Device X, will not effect the DC feed to your 12V converter. It will drain the battery faster then if it was not there.
Frank
I drew the sketch of the voltage meter display wrong. I made it look like a Ampmeter vs. a voltage meter, I attached new sketch.
Here is the voltage meter I am talking about. **broken link removed**
