ansonyeap
Member level 2
Hi all, recently i doing my post-layout simulation using ocean. the simulator that i used is spectre.
when the process is running, a notice from spectre pop up. the notice is as shown below.
Notice from spectre during topology check.
No DC path from node `I0.N_NET36_c_4352_p' to ground, Gmin installed to
provide path.
No DC path from node `I0.x_PM_NHP_REV1%NET30.259' to ground, Gmin installed
to provide path.
No DC path from node `I0.NET30' to ground, Gmin installed to provide path.
No DC path from node `I0.x_PM_NHP_REV1%NET36.50' to ground, Gmin installed
to provide path.
Warning from spectre during heuristic topology check - set topcheck=fixall to
fix all floating nodes.
No DC path from node `I0.x_PM_NHP_REV1%VDD.7159' to ground.
And when the simulation finished, all the result i get vary a lot from what i expected. what seem to be the problem and how to solve the above problem? furthermore, i check already my design, my design not suppose to be connected to ground for the corresponding nodes shown in the notice.
provide path.
to provide path.
to provide path.
