I want to check the layout performance compared to the circuit.
I remember we have to extract the layout for parasitic values..
And so, I have:
1-circuit schematic
2-extracted (parasitic)
And so, I have:
1-circuit schematic
You can use either config or simply insert your extracted view before your schematic view in your "analog enviroment" settings, and then run your simulation as before.
After extraction of RC you will get extracted view <filename>_extracted.
just go for schematic window find parasitics or parameters in 1st tab.
after that you will get a new tab called parasitics.in parasitics tab you will get back annotation option. next one import parasitics window will appear. just import extracted values from <filename>_extracted.
In the pre-simulation schematic veiw, build a config file, replace the schematic file with your extracted file in the popup config dialogue box, Run the just simulation file, the results you get this time are post-simulation ones
