ark5230
Advanced Member level 3
I need to use RTC DS1307 and EEPROM 24C256.
I tried to use RTC DS1307 using inputs from resources at https://www.dharmanitech.com
From this and similar resources I could successfully test RTC DS1307 and EEPROM 24C64 (so I hope 24C256 will not be much different.
My difficulty is that I am unable to combine both in one. Following link uses both in one but uses Atmega128. All details are available at the link but I dont (rather can not) use Atmega128 and want to implement it on Atmega32.
I am done if I cam port the atmega128 programs to atmega32 OR
I could combine the two in one, I2C combining both in one should be possible as I understand but I dont know how to implement it.
https://www.dharmanitech.com/search/label/serial%20EEPROM
Any suggestion or link to knowledge base and resource will be very much appreciated. I learnt a lot from this forum and now I am able to use C instead of assembly, life is easy in C but finer details become less important unless one is stuck up !!
