Port of rectangular patch antenna HFSS
neffi
Newbie level 3
Hi, i'm trying to simulate an antenna on HFSS but i don't know which type of port i should use and where to put it.
This is the antenna and how the s11 parameter should look like
But this is what i got
Thanks!
Hello neffi,
Select the circular face at the tip of the coax and assign a waveport, the integration line should be from the center core to the metallic shield. For more information look in this user guide:http://anlage.umd.edu/HFSSv10UserGuide.pdf there's an example about probe feed antenna
Thanks for your answer Nour Nachabe, it was really helpful
Now I have to get this
It's the near field plot but I don't know how to get it for each X and Y component
Reactions: Nuphi
    Nuphi
You r welcome, to plot the x and y components you should use the fields calculator (right click on Field overlays to open it), follow these steps to get the X component :1. Select E from quantity
2. Select Phase from function
3. Select AtPhase from complex
4. Select Scalar X from scal
5. Add it and name it
You can then make a surface at the distance you wish to see Ex, right click on the surface, plot fields, named expression and you choose the expression you just defined.
For more information on fields calculator look at : **broken link removed**
Good Luck
Thanks man!
Now my last request is this
Here, like the image says, I have to get the comparison of the cross-polarization levels as obtained from near field to far field transformation of the observation plane (the surface used previously) versus the radiation box for different angles
