eng.mserry
Newbie level 6
Iam designing a DC/AC inverter 12 VDC To 12 VAC and then to step up Tr. 12/ 220 volt
the problem with me is the gate driver IR2110 Or IR2113 i tried the both .... i always have a pulses on the the low output side pin 1 and i have nothing on High output side Pin 7 .... i can't find explanation to my problem
iam using two ceramic capacitors .47 micro farad .... and ultra fast rectifier ...the input on pin 10 , 12 in the aabove IR is 40 khz reversed pulses signals with 11 Vp.p and on the down IR 60 Hz reversed square signals with 11 Vp.p and dead time between them 10 micro second Vdd = 12 , Vcc = 12 v ....... and all connection as shown in the figure
Plz help me to solve this problem
