* This model card includes 5 kinds of device model of Hspice version: *
* 1. MOS Model *
* The MOS Model has 5 corners and each name as below: *
* .lib TT : Typical NMOS, Typical PMOS *
* .lib FF : Fast NMOS, Fast PMOS *
* .lib FS : Fast NMOS, Slow PMOS *
* .lib SF : Slow NMOS, Fast PMOS *
* .lib SS : Slow NMOS, Slow PMOS *
* 2. DIODE Model *
* The diode Model named: *
* .lib DIODE *
* When you use the model please make sure that the unit *
* of area is meter^2 and the unit of perimeter is meter when you *
* use the diode model. *
* 3. BJT Model(PNP) *
* The BJT Model named: *
* .lib BIP *
* There are 3 BJT models in this lib: *
* .model PNP10: with Emitter area = 100 um^2 (10x10) *
* .model PNP20: with Emitter area = 400 um^2 (20x20) *
* .model PNP5: with Emitter area = 25 um^2 (5x5) *
* Usage example: Q1 nc nb ne pnp5 *
* ( use default area=1) *
* 4. The Resistor Model has 6 kinds of resistors model: *
* 1) Nwell resistor *
* 2) N+ resistor *
* 3) P+ resistor *
* 4) Poly1 resistor *
* 5) Poly2 resistor *
* 6) HR(Poly2) resistor( 1k ) *
* 5.The Capacitor Model has PIP capacitor model. *
