I would like to ask your help on how can I plot my waveform result from Cadence Vertuso in Matlab. The reason is that the cadence waveform images is not good to attach in study report.
This is a design framework.
It has no relation.
Understand things correctly.
If your data format is .tr0, use HSPICE Toolbox.
If your data format is psf or sst2, use Spectre Toolbox.
However I don’t know whether Spectre Toolbox supports psfxl format or not.
Like circuitking said, csv formats work well. if you plot the data in virtuoso, or select it in the ADEXL window, you can export as csv. Importing the data into matlab will create a vector that you can then use simple plot commands to create your plot.
