Plotting using ansi c language
joammee
Junior Member level 1
How can I plot samples in .txt format using ANSI C language with gcc compiler? What are the commands to be used?
Thanks!
Graphing with plain C without using any other library or framework is usually a bad idea. Matlab would be easier to plot anything. If you are obliged to plot in C, you may want to use something like below or similar:
Simple DirectMedia Layer
Check the tutorials for further info.
LaTeX Commands Quick-Menu:
