Plot Problem SER versus SNR - obtained different values
saeddawoud
Full Member level 3
Plot Problem
I am trying to plot a formula in a paper, which plots the Symbol Error Rate (SER) versus Signal-to-Noise Ratio (SNR). But, I always obtain a curve that is different from the one obtained in the paper. It is of the same shape, but the values are not the same. What are the possible mistakes I did for this to happen?
Thanks in advance
Plot Problem
perhap they might be scaled values
Re: Plot Problem
Yes, but I double-checked every things, and I used the same parameters as it did, but always not the same. It is confusing.
Plot Problem
send the paper and code to check it
Re: Plot Problem
Thanks, but I wrote the code on Mathematica, since there are built-in functions available in it, that are not available in MATLAB. But I still can send them to you, and see if we can handle the problem using MATLAB. Do you agree?
Regrads
Plot Problem
i don't know mathmeticaa, also you know all papers done via matlab, however send the paper first
