alpacinoliu
Member level 3
How to see the total phsase noise at synthesizer output?
Here is my method.
freely run every block:
PFD+CHarge_Pump+filter in locking condition ----pss to save the output noise
saved in V.^2/Hz
VCO----pss to save phase noise in DB20
10.^(DB20/10)*4
divider----same
crystal----same
using noise source in new schematic to represent above noise source.
and create verilogA block to represent transfer function from noise to output,
and
AC+Noise
then you will see total ,
please minus 20log(4) from the result DB20
Here is my method.
saved in V.^2/Hz
10.^(DB20/10)*4
divider----same
crystal----same
and
AC+Noise
