PLL- Not locking due to charge pump
Ayyanar M
Junior Member level 1
Am having 1mV oscillation in VCO control voltage at locking time........ Because of this my vco output frequency is varying........ here i used charge pump current s 10uA.......
LPF components are:R=10Kohm ,C1=150pF,c2=15pF........
Can anyone give me a suggestion to lock this??
Is it oscillation (a loop stability problem) or is it just charge pump ripple?
1mV seems like you could pick up that noise almost anywhere.
This is because you chosed a high bandwidth for your PLL.
Try to reduce it and select also a good phase margin.
This will certainly solve your problem.
thanks to all...
Can anyone tell me how to calculate the total loop bandwidth of PLL in cadence?
And also phase margin?
What should be the range for these two for (upto 500MHz)?
Pls reply soon................
hi dick_freebird,
1mV oscillation is my LPF output that is VCO input... sorry dont consider the above phase noise plot.
see the attached waveform... there i found loop bandwidth and phase margin of the loop.........
Pls see it and reply me soon,,,,,,see the control voltage waveform too.....volt_control.png
