Hi all,
I'm in a fix about something here. I want to design a pll circuit that multiplies a varying frequency reference signal by 12. It is actually a square wave but not with a constant frequency. They are supposed to correspond to pulses (attached a figure of what I mean). Now my question is, will it work? I mean if the input is not a constant frequency signal how do I get the PLL circuit to work? Any ideas?
Secondly, if it works, will the pll output the square wave frequency × 12 or will it just multiply each pulse by 12 and output.
Lastly, can I put a switch on the PLL via 555 timer to switch it on and off at defined periods?
Thanks. I hope I made my question clear.
