[SOLVED] PLL Motor Control Design Question
E
elec_eng
Hi.
I was wondering if anyone could help me.
I need to use the Phase Locked Loop (PLL) technique to control the speed of a DC Motor. I have to use the LM565 chip. The data sheet can be found at **broken link removed** . I have attached the circuit confguration i plan to use below.
I will be using the 741 op-amp for the Low Pass Filter.
Is this configuration suitable?
If not, what changes would need to be made.
Any ideas or advice would be really useful.
Thank you for your time.
