Phase noise is measured as dBc/Hz. dBc stands for dB per carrier i.e measured noise power with respect to the carrier power. Phase noise takes a skirt like shape with noise being higher closer to the carrier. The offset frequency is the difference in frequency between the carrier and where the phase noise is measured. Cadence plots the X-axis as the offset frequency when plotting phase noise.
