sri4ever
Hello,
I'm new to VHDL. I have designed the 2 bit up counter using JK flip flop. But the test bench is not producing the results i need.
Please find attached the vhdl code and the test bench.
--- 2 bit counter with JK FF
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_unsigned.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity counterusingJK is
Port ( --JK: in std_logic_vector ( 1 downto 0) :="11";
CLK : in STD_LOGIC := '1';
RST : in STD_LOGIC := '0';
Qout : out STD_LOGIC_VECTOR(1 downto 0)
end counterusingJK;
architecture Behavioral of counterusingJK is
signal Q : std_logic_vector(1 downto 0);
signal JA,JB,KB : std_logic :='1';
signal KA : std_logic;
signal QA :std_logic := '1' ;
signal QB : std_logic := '1';
begin
KA <= QB;
--Q <= QA&QB;
process (CLK,RST)
begin
if (RST = '1') then
Q <= "00";
elsif (CLK ='1') then
Q <= (QA&QB)+1;
end if;
end process;
Qout <= Q;
end Behavioral;
Test Bench for 2 bit counter
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
--USE ieee.numeric_std.ALL;
ENTITY UPcounter IS
END UPcounter;
ARCHITECTURE behavior OF UPcounter IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT counterusingJK
PORT(
CLK : IN std_logic;
RST : IN std_logic;
Qout : OUT std_logic_vector(1 downto 0)
END COMPONENT;
--Inputs
signal CLK : std_logic := '0' ;
signal RST : std_logic := '0';
--Outputs
signal Qout : std_logic_vector(1 downto 0) ;
-- Clock period definitions
constant CLK_period : time := 10 ns;
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: counterusingJK PORT MAP (
CLK => CLK,
RST => RST,
Qout => Qout
-- Clock process definitions
CLK_process rocess
begin
CLK <= '0';
wait for CLK_period/2;
CLK <= '1';
end process;
-- Stimulus process
stim_proc: process
begin
--wait for clk_period*20;
RST <= '1';
--CLK <= '1';
-- hold reset state for 100 ns.
wait for 10 ns;
-- wait for CLK_period*10;
RST <= '0';
--CLK <= '1';
wait for 10 ns;
-- insert stimulus here
wait;
end process;
END;
Kindly suggest where could be the mistake.
Thanks,
Sri
library IEEE;
--library UNISIM;
end counterusingJK;
begin
KA <= QB;
--Q <= QA&QB;
process (CLK,RST)
begin
if (RST = '1') then
Q <= "00";
Q <= (QA&QB)+1;
end if;
end process;
Qout <= Q;
end Behavioral;
LIBRARY ieee;
ENTITY UPcounter IS
END UPcounter;
PORT(
CLK : IN std_logic;
RST : IN std_logic;
END COMPONENT;
--Inputs
--Outputs
BEGIN
CLK => CLK,
RST => RST,
Qout => Qout
CLK_process rocess
begin
CLK <= '0';
CLK <= '1';
end process;
-- Stimulus process
stim_proc: process
begin
RST <= '1';
--CLK <= '1';
wait for 10 ns;
RST <= '0';
--CLK <= '1';
wait for 10 ns;
wait;
end process;
END;
Thanks,
Sri
