please tell me the pin description of a 12v relay
immadi.jagadish
Member level 5
i am connecting a circuit by using which we can turn on or off any equipment by using remote.
In connecting that am facing problem about where to connect those pins.My relay has 5 pins,one side 3 pins and another side 2 pins.please tell me which pin is used for what and where they are connected.
It's number is JQC-3Fc(T73)DC12v.
Please help some one.
It shown in the datasheet
The link is very slow so I'm attaching the file
  • cn_p__57.pdf
All you need is the image in the lower right corner.
It shows the two pins for the coil and the three pins that are connected to the switch
---------- Post added at 09:57 ---------- Previous post was at 09:54 ----------
Here is an English version
this is my circuit , connected diode in between the relay's one side in which there are two pins, is that the right way to
connect?
  • CI-01_May05.pdf
Here is the pin diagram of the same:
Hope it solves your problem.
This shows the pins as viewed from below, the pin side
coil1 and coil2 is the control coil , where the diode is connected in your schematic
the other three pins are the switch
in your schematic there is only one diode and it is connected across the input coil ends coil1 and coil2 so if you mean that you have connected N/O and N/C instead of the coil then it is wrong
so i have to connect the diode to that side where there are three pins .where do i connect the middile pin of the three pins .
is it left opend?
No the middle of the three pins is the center of the switch, in your schematic it is connected to the output bulb.
Note that the output of your relay (at least as shown in the schematic) is connected to the mains (220v) so be very careful, don't touch it while it is powered.
I would suggest you try the circuit either with a small low voltage lamp or with a led and a low voltage source until it is tested to work properly, then if you want you can use a mains bulb.
but according to the my schmatic ,diode is connected in between two pins, bulb is connected in between n/o and middle
switch and n/c left open.
Yes your bulb is connected between the center pin of the switch and N/O , N/C is left open.
The transistor drives the relay control coil (coil1 and coil2 pins)
I don't see the problem.
i am still in confusion as i was before posting my first post .i take from the notch which is there on the top of relay
(notch rectangular in shape),to the left of it two pins,to the right it two pins and exactly below the notch one pin is there.Please tell me in that way which pin connected where.
the datasheet and my attachment in post #7 show the pins viewed from the bottom side.
Turn the relay upside down so that you are facing the pins not the plastic cover side, then it is easy to figure the pins since one side has three and the other side two.
    V
please tell me sir your valiable feed back
