please rectify the code
thannara123
Advanced Member level 5
India
I am wrting to here a part of my code , when it run works normally at the red colored section
while(1){
                  [COLOR=#ff0000]  LCD_clear;
                    password=  InputNumber("Enter Password");//Get the keycode of pressed key
                    if(password==ReadPassFromEEPROM())
                          LCD_clear;
                          string(" Unlocked");
                          _delay_ms(100);
                          while(1)     {
                         f=GetKeyPressed();
                           while(GetKeyPressed()==255)
                               _delay_loop_2(10);
                            if (f==2){ [/COLOR]
                                password==InputNumber("old");    // not getting values
                                _delay_ms(300);
                                if (password==ReadPassFromEEPROM())
                                    newpassword=InputNumber("new");
                                    string("just testing");
                                    WritePassToEEPROM(newpassword);
                                    _delay_ms(300);
Logic :
1) If(f==2) it will ask old password
2) Enter the oldpassword
3) check the password is matched with EEPRO
4) if yes ask new password and write to EEPRO
4) else invalid
please help me
uint16_t InputNumber(char *msg)
	uint8_t keyCode;
	int x=0;
	int pos=0;
	uint8_t prev_key=0xFF;
	uint8_t k=0xc1;
	uint8_t system_reset = 0;
	int key[4];
	dis_cmd(0x81);
	while(*msg) dis_data(*msg++);
     LINE2;
		while(!system_reset)
			keyCode=GetKeyPressed(); 							//Get the keycode of pressed key
			if(pos==4|keyCode==2)
				pos==0;
				return(((1000*key[0])+(100*key[1])+(10*key[2])+key[3]));		//save the password in 16 bit integer
				break;
			if(keyCode==prev_key)
			continue;
			else if(keyCode==0xFF)
				prev_key=0xFF;
				continue;
			else
				prev_key=keyCode;
switch (keyCode) 									//generating key characeter to display on LCD
	case (11):
	string("1");
	dis_cmd(k++);
	key[x]=1;
	x++;
	pos++;
	break;
	case (10):
	//dis_cmd(k++);
	string("2");
	dis_cmd(k++);
	key[x]=2;
	x++;
	pos++;
	break;
	case (9):
	string("3");
	dis_cmd(k++);
	key[x]=3;
	x++;
	pos++;
	break;
	case (8):
	string("4");
	dis_cmd(k++);
	key[x]=4;
	x++;
	pos++;
	break;
	case (7):
	//dis_cmd(k++);
	string("5");
	dis_cmd(k++);
	key[x]=5;
	x++;
	pos++;
	break;
	case (6):
	string("6");
	dis_cmd(k++);
	key[x]=6;
	x++;
	pos++;
	break;
	case (5):
	string("7");
	dis_cmd(k++);
	key[x]=7;
	x++;
	pos++;
	break;
	case (4):
	string("8");
	dis_cmd(k++);
	key[x]=8;
	x++;
	pos++;
	break;
	case (3):
	string("9");
	dis_cmd(k++);
	key[x]=9;
	x++;
	pos++;
	break;
	case (2):
	//string("*");
	//dis_cmd(k++);
	key[x]=0;
	x++;
	pos++;
	break;
	case (1):
	string("0");
	dis_cmd(k++);
	key[x]=0;
	x++;
	pos++;
	break;
	case (12):
	system_reset=1;
	break;
	//default: ;
_delay_loop_2(300);
attaching the project file please look it
  • New folder.rar
defult value is 5050 unlocked
then press * to change password ie (f==2)
thanks working but when re-enter old password only three digit can enter why so sir ?
No .. problem still..
I think ..
if(pos==4|| keyCode==2)
{ h=0;
pos=0;
x=0;
keyCode=GetKeyPressed();//Get the keycode of pressed key // it makes again pos=1 that may be the reason but how clear
Why are you using pos, x , and k. You can just use x. Replace pos and k with x like this
case (11):
	string("1");
	key[x]=1;
        dis_cmd(x++);
	break;
and
 if(x==4|| keyCode==2)
Post the Code for GetKeyPressed() function. Send me the .cof file for your code. I will debug and see.
full project code as follows
                       [COLOR=#FF0000]  Main .c[/COLOR]
#include<avr/io.h>
#include<avr/eeprom.h>
#include<util/delay.h>
#include<inttypes.h>
#include "eeprom.h"
#include "lcd.h"
//#include "keypad.h"
#include "user_interface.h"
int main(void)
    DDRB=0xFF;
    lcd_init();
        uint16_t password;
        uint8_t f;
        uint16_t newpassword;
        if(ReadPassFromEEPROM()==25755)
            //Password is blank so store a default password
            WritePassToEEPROM(5050);
            _delay_ms(400);
        LCD_clear;
        LINE1;
        dis_cmd(0x84);
        string("Drive");
      _delay_ms(200);
    while(1){
                    LCD_clear;
                          LCD_clear;
                          _delay_ms(100);
                          while(1)     {
                         f=GetKeyPressed();
                               _delay_loop_2(10);
                            if (f==2){
                                password=InputNumber("Old Password");
                                _delay_ms(1000);
                                    string("okok");
                                    _delay_ms(300);
                          else
                              LCD_clear;
                              string("Wrong Password");
                              _delay_ms(1000);
                  [COLOR=#FF0000] interfacing /decoding section file .c[/COLOR]
#include <avr/io.h>
#include <inttypes.h>
#include "keypad.h"
#include "lcd.h"
    uint8_t keyCode;
    uint8_t x=0;
    uint8_t pos=0;
    uint8_t k=0xc1;
    int key[4];
    uint8_t h=0;
    dis_cmd(0x81);
     LINE2;
        while(1)
             if(h==4)
                 {    pos=0;
                x=0;
            continue;
                prev_key=0xFF;
                continue;
            else
                prev_key=keyCode;
              h++;
    case (11):
    string("1");
    dis_cmd(k++);
    key[x]=1;
    x++;
    pos++;
    break;
    case (10):
    //dis_cmd(k++);
    string("2");
    dis_cmd(k++);
    key[x]=2;
    x++;
    pos++;
    break;
    case (9):
    string("3");
    dis_cmd(k++);
    key[x]=3;
    x++;
    pos++;
    break;
    case (8):
    string("4");
    dis_cmd(k++);
    key[x]=4;
    x++;
    pos++;
    break;
    case (7):
    //dis_cmd(k++);
    string("5");
    dis_cmd(k++);
    key[x]=5;
    x++;
    pos++;
    break;
    case (6):
    string("6");
    dis_cmd(k++);
    key[x]=6;
    x++;
    pos++;
    break;
    case (5):
    string("7");
    dis_cmd(k++);
    key[x]=7;
    x++;
    pos++;
    break;
    case (4):
    string("8");
    dis_cmd(k++);
    key[x]=8;
    x++;
    pos++;
    break;
    case (3):
    string("9");
    dis_cmd(k++);
    key[x]=9;
    x++;
    pos++;
    break;
    case (2):
    //string("*");
    //dis_cmd(k++);
    key[x]=0;
    x++;
    pos++;
    break;
    case (1):
    string("0");
    dis_cmd(k++);
    key[x]=0;
    x++;
    pos++;
    break;
    case (12):
    break;
    //default: ;
_delay_loop_2(300);
    pos=0;
    x=0;
Keypad.h file
 * keypad.h
 * Created: 12/19/2012 10:49:06 PM
 *  Author: Gelectorn
#ifndef KEYPAD_H_
#define KEYPAD_H_
#define KEYPAD_PORT PORTD
#define KEYPAD_DDR   DDRD
#define KEYPAD_PIN   PIND
uint8_t GetKeyPressed()
  uint8_t r,c;
  KEYPAD_PORT|= 0X0F;
  for(c=0;c<3;c++)
        KEYPAD_DDR&=~(0X7F);
        KEYPAD_DDR|=(0X40>>c);
        for(r=0;r<4;r++)
            if(!(KEYPAD_PIN & (0X08>>r)))
                return (r*3+c);
      return 0XFF;//Indicate No key pressed
#endif /* KEYPAD_H_ */
It displayes "Old Password" and the user has to enter the old password. Why is it necessary. Already the user has entered the old password and it is checked with the value of the eeprom and "Unlocked" has been displayed. Why the old password needs to be entered a second time?
You have used another variable h, so you have to clear it.
 if(h==4)
          {    pos=0;
               x=0;
               k=0;
               h=0;
sir that just for privacy . thanks for advise i plan to avoid that ..
h==0; is the variable to check whether entered 4 times key pressed .(just changed variable pos to h - just for trying)
It is happening because of the code
When you enter 5050 pos will be 4 and you have to clear it. input will be the value corresponding to 0 in 5050. so pos will be 1 because case for key value 0 will be executed. So, you have to clear input when you clear x, k, h, and pos.
Post the latest project files. I am getting nubere if I press 5. The keypad is giving wrong values.
sorry for the latency ..
I am attaching the eeprom and hex file for the proteus .please check it
sir if you can just check the code
my problem is it will run password= InputNumber("Enter Password"); first time correctly and ask password ,if enter correct passowrd , shown unlokced. there is no problem.
but when i press * that keycod is 2 (if(pos==2)) call the above said same function ie,password=InputNumber("Old Password"); here araise a problem i can onle enter the 3 digit (there is need to enter 4 digit ) if you can please help me thanks
i am submitting my code here
                                   main file
#include<avr/io.h>
#include "eeprom.h"
#include "lcd.h"
int main(void)
    DDRB=0xFF;
    lcd_init();
        uint16_t password;
        uint8_t f;
            _delay_ms(400);
        LCD_clear;
        LINE1;
        dis_cmd(0x84);
        string("Drive");
      _delay_ms(200);
    while(1){
                    LCD_clear;
                          LCD_clear;
                          _delay_ms(100);
                          while(1)     {
                         f=GetKeyPressed();
                               _delay_loop_2(10);
                            if (f==2){
                                _delay_ms(1000);
                                    string("okok");
                                    _delay_ms(300);
                          else
                              LCD_clear;
                              _delay_ms(1000);
            interface/keypad convertor
#include <avr/io.h>
#include "keypad.h"
#include "lcd.h"
    uint8_t keyCode;
    uint8_t x=0;
    uint8_t pos=0;
    uint8_t k=0xc1;
    int key[4];
    uint8_t h=0,l=0;
    dis_cmd(0x81);
     LINE2;
        while(1)
             if(h==4)
            {    pos=0;
                x=0;
                keyCode=0;
                k=0x80;
                _delay_ms(100);
                h=0;
                break;
            continue;
                prev_key=0xFF;
                continue;
            else
                prev_key=keyCode;
                h++;
    case (11):
    string("1");
    dis_cmd(k++);
    key[x]=1;
    x++;
    pos++;
    break;
    case (10):
    //dis_cmd(k++);
    string("2");
    dis_cmd(k++);
    key[x]=2;
    x++;
    pos++;
    break;
    case (9):
    string("3");
    dis_cmd(k++);
    key[x]=3;
    x++;
    pos++;
    break;
    case (8):
    string("4");
    dis_cmd(k++);
    key[x]=4;
    x++;
    pos++;
    break;
    case (7):
    //dis_cmd(k++);
    string("5");
    dis_cmd(k++);
    key[x]=5;
    x++;
    pos++;
    break;
    case (6):
    string("6");
    dis_cmd(k++);
    key[x]=6;
    x++;
    pos++;
    break;
    case (5):
    string("7");
    dis_cmd(k++);
    key[x]=7;
    x++;
    pos++;
    break;
    case (4):
    string("8");
    dis_cmd(k++);
    key[x]=8;
    x++;
    pos++;
    break;
    case (3):
    string("9");
    dis_cmd(k++);
    key[x]=9;
    x++;
    pos++;
    break;
    case (2):
    //string("*");
    //dis_cmd(k++);
    //key[x]=0;
    //x++;
    //pos++;
    break;
    case (1):
    string("0");
    dis_cmd(k++);
    key[x]=0;
    x++;
    pos++;
    break;
    case (12):
    break;
    //default: ;
_delay_loop_2(300);
 * keypad.h
 *  Author: Gelectorn
#ifndef KEYPAD_H_
#define KEYPAD_H_
  uint8_t r,c;
  KEYPAD_PORT|= 0X0F;
  for(c=0;c<3;c++)
        for(r=0;r<4;r++)
                return (r*3+c);
  • Debug.rar
