Re: rate the tools
initialy when i used P*otel 1.5(less than three Mb), i thought that the worst thing to do was design PCB using CAD, and was doing boards with manual methods(good old bishop graphic Tapes) later when i tried P*otel DXP i get the same feeling. there is no control when you route manualy, it zaps into wilderness and you dont find where your alyout has ended, controlled placing of components is difficult, and requires wast system resources,. frequent system crashes were common.
Later i tried Pcad, it is difficult to use this tool unless you work on it for a lot of time.
presently using Eagle and i find that the learning curve is very less with Eagle. if your layout is not very complex and dont need simulation eagle is best choise.
the higher end PCB tools have exotic features like autoplace, smart routing etc, but i think people seldom use autoplacement option, and i dont think that any tool can think like what a human brain does. i got disastrous results with autoplacer in Pro*el.
POLL: 1:HOW MANY PEOPLE USE AUTOPLACEMENT
2: WHAT IS THE LEVEL OF ROUTING RESULTS YOU GET WITH AUTOROUTER WITH VARIOUS TOOLS.
3: DO DESIGNERS REALLY DEPEND ON AUTOROUTERS.
4: IS A 3D TOOL REQUIRED( they charge money for such features)
finally every tool has its pros and cons and to expect everything from from a single tool is useless. the choise of tools should be based on the following points
1: the cost of tool and your requirement.
2: ease of use.
i came to a conclusion after testing many EDA tools that if you are designing Power supplies, Small micrprocessor boardswhere maximum placement and routing is done by hand it is waste of money to use Cadence tools or any other high end tools, a program like EAGLE is available for 1200$ . if you require only layout module it is around 400$ where high end tools cost in the range of 5000$ to 10000$.
Think wisely before investing on any PCB design tool.
8)
