please help me with pic16f877a
xairz
Newbie level 2
Newbie level 2
im having problem to light on led using irpd sensor . can anyone help how to make the led on . this is my coding . please . help me anyone :-(
#include <16f877a.h>
#device adc=8
#use delay(clock=20000000)
#fuses hs,noprotect,nowdt,nolvp
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,parity=N)
#byte PORTa=5
#byte PORTb=6
#byte PORTC=7
#byte PORTd=8
#byte PORTe=9
void main()
int value1,value2;
//set_tris_b(0b00000000);
set_tris_d(0b00000000);
setup_port_a(ALL_ANALOG);
setup_adc(ADC_CLOCK_INTERNAL);
do
set_adc_channel(0);
value1=read_adc();
//printf("read S %u",value1);
delay_ms(1000);
portd = value1;
set_adc_channel(1);
value2=read_adc();
//printf("read S %u",value2);
delay_ms(1000);
portd = value2;
if(value1 > 1)
output_high(pin_D7);
//delay_ms(1000);
else
output_low(pin_D6);
//delay_ms(1000);
//output_low(pin_D5);
while(1);
your help means a lot to me
whats problem in your code. I mean what you want to do..
john : yes , i set it correctly . do you think it set wrong ?
rajbabu : i don't know . im using an irpd sensor . it just like ir sensor . when it detect object or obstacle , led will light on .
thunder : im using ccs , the problem is when on the board . nothing happen . the sensor also not light on , the output should make led on . but nothing happen
this is sensor im been using
IRPD-01 IR Proxinity Detector - discover electronics and robotics
Their may be two problem:
1. in hardware
check output of sensor without connecting to uC.
if it is coming right then conect to uC and check.
if output of sensor deviating from previous value then add pull up resistance on that pin.
2. in software
make input pin to it or change pin.
Rajbabu :cool:
