BuBEE
Full Member level 2
centos tftp
Hello
I just start to learning FPGA and uclinux. I have some problem about TFTP installation.
i installed with
Then , I created directory with
after that , I edit "disable = yes" in /etc/xinetd.d/tftp to "disable=no" (this shows below)
then , I restart service with and check with netstat
and final step , I created file "test" and save to /tftpboot folder
and I test tftp with
result show
I tried to reinstall and reconfig again and again but everything not work.
anyone please help
Thank you
BuBEE
ps. i turn off "SELinux" and turn off "firewall" already
Hello
i installed with
$ yum install xinetd tftp-server tftp
$ sudo mkdir /tftpboot
$ sudo chmod -R 777 /tftpboot
$ sudo chown -R nobody /tftpboot
service tftp
protocol = udp
port = 69
socket_type = dgram
wait = yes
user = nobody
server = /usr/sbin/in.tftpd
server_args = /tftpboot
disable = no
$ sudo /etc/init.d/xinetd restart
tftpd service is up and running
$ netstat -l -u │ grep tftp
udp 0 0 *:tftp *:*
$ tftp localhost
tftp> get test
result show
Transfer timed out.
anyone please help
Thank you
BuBEE
