wtk_analog
Newbie level 1
i am going to design digital block. This block is part of mixed circuit. Then, digital part is designed by verilog and analog part is designed by cadence.
i have 1 problem. my design block don't use pad because digital block and analog block is combined by cadence virtuso. i found the some icc design flows but this design flows have case of using pad.
i look for how to design without pad. Use only pin or port also make port power and ground.. please help me. thank you
