you need anther divac with PLC to measuring power factor and divide the capacitor bank to multi step.
when power factor decrease the measuring divac will send signal to PLC and PLC will add anather step power circuit to increase power factor.
good luck
PLC is controller,U can not use only PLC to do that. U can use PLC to control Capacitors Bank like above. U also can use PLC to control another power equipment to improve PF.
good luck
Hi, first of all thanks for your reply. You gave me a headstart, really appreciate it.
May I ask what is a DIVAC?
Can't get any information about the component you mentioned.
Total noob here.
