The PlanAhead system is employed between synthesis and place & route enabling designers to implement a block-by-block implementation approach. The tool adds functionality to help Virtex-4 designers rapidly analyze, modify and achieve superior performance on each of the blocks. Blocks can then be stitched together in a final assembly phase.
The PlanAhead v2.2 solution is immediately available for use with the Integrated Software Environment (ISE) 6.3i FPGA design suite from Xilinx. The tool is priced at $15,000.
ylscqu said:Will the planAhead been included in ISE?
