sunnyiq
Newbie level 3
Look! I had a platinum heater which look small in size like a chip, the size of it is 15mm x 13 mm, thickness not more than 1 micro meter, the temperature range is more than 300 degree celsius.. does any one know how to connect the heater with wire to make a close system!
Note. Using clip to hold the heater doesnt seem work, because the heater will brake at certain temperature.
