PIR - RPW100 pinout and datasheet needed
microlost
Member level 1
Matrix Bus
RPW100 pinout
Hello,
need to know if anyone knows the pinout of this PIR.
and physical property, I find its datasheet anywhere, be that Philips and its code is RPW100, nothing more,
any ideas?
thanks in advance
regards.
RPW100 pinout
Unfortunately you need a Philips Sensor data book from 1989/1990. I have a 1986 one but it isn't in there. NXP (what Philips are now called) haven't got the data sheet on their web site. You could guess at it being like a more modern equivalent, although I guess you could blow it up. Look at the D203B for example
Sorry I cannot be more help.
Keith.
I would expect a pinout, as it can be found with any industry standrad PIR sensor
The more interesting point is the sensor type, e.g. single or dual element (motion detector), filter passband. But perhaps you know
about these general features.
    microlost
hello,
jejej if it's something old ...
wanted to serve these old PIR for a robotics project ...
as I have over 20 in my store, are reverse engineering something ..
is stronger than me, when I see some old component, I want control j.ejejejej
thank you all so
regards.
I see, that the device is mentioned in literature occasionally, it's clearly a dual-element motion detector with a standard
6.5 -14 µm bandpass (for indoor use). So there aren't much open questions, actually.
